Date/Time: Wed, 01 May 2024 05:06:46 +0000
Color Bar study not working
View Count: 1349
[2014-10-07 21:38:38] |
jivetrader - Posts: 379 |
VBBR (ID:5) bars should be colored yellow when >850. trigger works but bars do not color, regardless of the relative position of the Color Bar Alert study in the Study list. please advise thanks. |
vbbr issue2.png / V - Attached On 2014-10-07 21:36:15 UTC - Size: 252.08 KB - 341 views |
[2014-10-09 10:14:52] |
If you want to color the Subgraph of another study follow the instructions here: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s245 Specifically the section named "Coloring Subgraphs of Other Studies". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-10-10 04:16:22] |
thank you. i got it working. a follow up question, from the link in your reply: >>Set the Draw Style of the Color Bar Subgraph to be the same as the Subgraph of the other study you are coloring. In the case where you are coloring a study Line, it is recommended to use the Line-Skip Zeros Draw Style. Otherwise, the appearance of the line will not be correct.<< what if the other study is Graph Draw Type=Candlestick, where the only Draw Style options are [Visible, Ignore] e.g. Value Charts study. thanks again. |
[2014-10-10 07:20:40] |
In this case use Color Bar and we will update the documentation to explain this.
