Date/Time: Wed, 25 Nov 2026 16:15:00 +0000
Prix ouverture/fermeture ETH ete RTH
View Count: 504
[2025-08-05 15:32:53]
User914407 - Posts: 65
Bonjour,
J'essaie de paramétrer la study "Horizontal Line at time" pour avoir les heures d'ouverture/fermeture du CME et de l'EUREX mais je n'y arrive pas.
Pouvez-vous m'aider ?
Merciautomatiquement
[2025-08-05 15:58:58]
From Google Translate:
I'm trying to configure the "Horizontal Line at Time" study to get the opening/closing times of the CME and EUREX, but I'm having trouble.
Can you help me?
We need to know what exactly you are wanting to accomplish. What do you want to see?
[2025-08-05 16:11:23]
je veux simplement une ligne pour chaque prix d'ouvertures, fermetures ETH/RTH et pour l'EUREX et le CME
[2025-08-05 16:12:33]
I just want one line for each ETH/RTH opening and closing price and for EUREX and CME
How do you want the line to be displayed? Does it need to go across the entire chart, or just over some portion of it?
[2025-08-05 16:46:54]
Can you give me the 2 solutions please ?
[2025-08-05 21:14:33]
The general answer is that you should use the "High/Low for Time Period - Extended" study. You will need 4 copies of this for each symbol in order to capture the Open of the ETH, the Close of the ETH, the Open of the RTH, and the Close of the RTH.
For this study, you will set the "Start Time" and "End Time" to the start and end of the bar that contains the particular item you want. For instance, if you are using 5 minute bars and the ETH starts at 17:00:00, then you would enter the following:
- Start Time: 17:00:00
- End Time: 17:01:59
You would set the "Input Data High" to be the particular item for that specific instance of the study. So to continue with the above example, you are wanting the open for the ETH, so set the "Input Data High" to be "Open". Then on the Subgraphs set the "Low" subgraph Draw Style to "Ignore".
For each item you can then extend the line as you want through that study.
If you want the line extended more than what it does, you would need to use the "Spreadsheet Study" to copy the line value through to the times where you want the line displayed.
Refer to the following:
Chart Studies: Ignore (ACSIL: DRAWSTYLE_IGNORE)
