Date/Time: Sun, 05 May 2024 09:57:07 +0000
get data from 'Numbers Bars Study'
View Count: 1400
[2014-10-07 15:00:39] |
User60891 - Posts: 7 |
Hello. I'm creating a trading system with 'Spreadsheet System for Trading'. I need to get data from 'Numbers Bars Study' at the specified price level. I mean that each bar has price levels from Low to High. 'Numbers Bars' study creates new bars with new values at these price levels. So how can i get these values from my Spreadsheet? |
[2014-10-07 16:28:47] |
In the version of Sierra Chart with "New Spreadsheets" there is a new Input setting with the Spreadsheet studies named Output Volume at Price Data. This will give you the data that you need.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-10-07 16:29:03
[2014-10-08 13:16:02] |
Thank you for an answer. I found this option in Spreadsheet's settings. But i can't see any difference in the spreadsheet. I can't find any description of this option. Could you please give more details how to use this option?
[2014-10-09 09:10:16] |
Here is the documentation for this: http://www.sierrachart.com/index.php?page=doc/doc_SpreadsheetStudyInputs.html#OutputVolumeAtPriceData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-10-09 14:45:03] |
Great, now i see it. Thank you very much. By the way, is it possible to get bid and ask volume at price separately?
[2014-10-09 17:06:41] |
No, this is not supported.
[2014-10-10 05:39:05] |
Ok, thank you
[2014-10-10 10:21:00] |
ganz - Posts: 1048 |
SC Support are there any plans to add VbP or NB ACSIL members? thnx. |
[2014-10-10 15:37:08] |
We do not understand the last question. We assume you already know you can access the Volume at Price data in ACSIL. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-10-10 18:30:35] |
SC Support I mean to set inputs and to get values from VbP for standard or custom period: POC, VAH,VAL, peaks/valleys using an ACSIL VbP member. The same qstn is for TPO. thnx. Date Time Of Last Edit: 2014-10-10 18:30:48
[2014-10-10 19:13:21] |
For Volume/TPO POC, VAH,VAL, add the Volume/TPO Value Area Lines study to the chart and reference the Study Subgraphs from ACSIL.
[2014-10-10 19:32:48] |
SC Support Pls., I hope I'm familiar to the current abilities. So the question wasn't about that. thnx. |
[2014-10-10 19:47:35] |
SC Support This is all about to calculate R/S zones automatically. Volume VA Lines is time-based only study so one couldn't use Range, Renko or similar event-based price action to develop a VbP -based trading system. Date Time Of Last Edit: 2014-10-10 19:52:11
[2014-10-10 19:53:04] |
SC Support the post #13 has been edited. thnx. |
