Date/Time: Wed, 25 Nov 2026 16:14:59 +0000
CME Market Depth
View Count: 545
| [2025-08-04 12:39:16] |
| noumantrades - Posts: 14 |
Hello Team. I am running Sierra on two different PCs and I have subscribed to CME Top of the book subscription. Is t possible to upgrade to CME Market Depth Data for only one of my PC and the other one can just have top of the book? |
| [2025-08-04 18:42:42] |
No, this is not possible, at least not in terms of the exchange options. Whatever exchange options you have active, you need to pay the double exchange fees since you have the option for 2 systems enabled. And there is not a way to define a specific exchange to a specific system. If you want to have one system not showing the Market Depth data, then set the following option to "1" on that system, so you are only getting 1 level of Market Depth data coming in: Sierra Chart Server Settings: Max Depth Levels (Global Settings >> Sierra Chart Server Settings >> General >> General) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
