Date/Time: Wed, 25 Nov 2026 16:15:03 +0000
List of broker that supports Denali Teton data and also Sierra Chart
View Count: 2247
[2025-08-04 07:16:42]
User193762 - Posts: 18
Can you tell me the list of brokers that supports Denali Teton data and also Sierra Chart?
[2025-08-04 16:11:58]
The list of brokers that support the Teton Order Routing service can be found in Step #2 at the following link:
Sierra Chart Teton Futures Order Routing: Setup Instructions
There is not a list of all brokers that support the use of Sierra Chart, as Sierra Chart can be used with most brokers that use Teton, Rithmic, or CQG for order routing. Refer to the following:
Supported Data and Trading Services
There is a partial list of brokers at the following link:
https://www.sierrachart.com/index.php?page=doc/OtherSitesLinks.php#Brokers
[2025-08-04 16:59:56]
User587476 - Posts: 32
Today I am unable to trade ES and NQ. I asked my broker and they informed me that Sierra chart does not support CQG data, but GC can be traded. However, you mentioned that it can be connected. Is this true.?
When I choose Rithmic, there is no list of servers to choose from. Do you have any tutorials on how to connect to Rithmic,
Thank you for answering my question
[2025-08-04 19:59:52]
Sierra Chart does not have support for CQG data for the CME Group and EUREX. This has been the case for several years now.
You can use our Denali Exchange Data Feed for the data and trade with CQG.
We see that you have the following exchanges active:
- COMEX Non-Professional Top-of-Book
- NYMEX Non-Professional Top-of-Book
Therefore, you have access to the GC (Gold) data as that is traded on the COMEX exchange, for which you are setup to get data. ES and NQ are traded on the CME exchange, for which you are not setup to get any data.
If you want to add the CME exchange, then you can do so at the following link:
https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges
Refer to the following - in particular steps 8 through 11:
Rithmic Trading Platform Service: Setup Instructions
