Date/Time: Wed, 25 Nov 2026 07:56:07 +0000
DOM Columns Saving
View Count: 717
[2025-08-03 19:13:49]
KylieV1618 - Posts: 79
Is there a way to setup the DOM columns how I like, and then just have them, default to the everytime, unless I specificall click Use Default
That would be very helpful for quickly opening a DOM, thats just immediately configured.
[2025-08-04 15:54:29]
Refer to the following:
Using Chart Templates: Duplicating Charts / Template Charts
[2025-08-04 16:02:57]
Yes im aware.
But many times I just wanna open a dom quickly. Without having to open a chartbook to duplicate it and then go back to the other chartbook.
I simply just want to open DOM look at it and then maybe close.
It would be helpful if all my columns were just set everytime I do that.
[2025-08-04 19:20:04]
There is not a way to do this the way you are asking in Sierra Chart. The only option is to use an existing DOM and duplicate it.
[2025-08-04 19:29:15]
No i know there's not a way. Im asking for a feature request
[2025-08-04 20:40:50]
We have set this as a Feature Request. We can not say when we can get to any particular request.
[2025-09-02 14:35:26]
Sierra_Chart Engineering - Posts: 25479
This is never going to be added at all. It will never happen. You need to use this method here:
