Date/Time: Wed, 25 Nov 2026 16:03:16 +0000
Chart Values for Tools Sub-graphs
View Count: 788
| [2025-08-03 11:54:10] |
| User532947 - Posts: 17 |
Hi I want to limit the values displayed in the Chart Values for Tools window to Last (price). In the Study settings / Subgraphs/ Graph Draw type / Line on Close I have selected Ignore for all Draw Styles apart from Last. The Open High Low Volume etc are still displayed in the Chart Values for Tools window. Below if I also uncheck all options apart from Display Study Subgraphs Name and Value - Global and then toggle; the values are displayed or not displayed but I cannot choose which value to display (i.e. Last) Chart Studies: Subgraphs Tab >> Display Name and Value in Chart Values Windows https://www.sierrachart.com/index.php?page=doc/helpdetails67.html#HidingStudyNamesValuesVWRDL BR Tim. |
| [2025-08-03 12:24:16] |
Omitted that the study applied is Add Additional Symbol.
| [2025-08-03 16:03:46] |
| Sierra_Chart Engineering - Posts: 25481 |
We do not see any problems with this. For each Subgraph of the Add Additional Study, uncheck Display Name and Value in Chart Values Windows if you do not want to see it displayed in the Values Windows.
| [2025-08-04 20:08:14] |
Hi Unchecking Display Study Subgraphs Name and Value - Global removes the values but unfortunately I'm left with the Symbol name (e.g. Symbol: EURAUD ID:6) and a line for Price Chg. I want the Symbol name and the Last price. Unchecking Display Name and Value in Chart Values Windows just removes the Open price from the Chart Values for Tools window. I only have Draw style Visible selected for the Subgraph /Last Are you able to replicate this behaviour? Add Additional Symbol / Line on close / Subgraph /Last /Draw style Visible ( all other Subgraph Draw styles set to Ignore) |
| [2025-08-04 20:59:19] |
The option for "Display Name and Value in Chart Values Windows" is a per subgraph setting. So you need to uncheck that option for each subgraph, except the subgraph for the "Last". This is exactly the same as the "Draw Style" - you need to select each subgraph and deselect that option. We are also wondering if you are referring to the Main Price Graph information in the Chart Values Window or perhaps the Region Data Line, as you refer to "Price Chg". Please get us an image of what you are referring to. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-08-18 14:46:26] |
Hi John, Yes I needed to deselect "Display Name and Value in Chart Values Windows" for each subgraph attribute except "Last" as well as ignore the Draw Style. I could not quickly work out where the "Price Chg" field in the Chart Values for Tools window toggles but it does not bother me. Thanks for spending time on this. KR Tim.
