Date/Time: Wed, 25 Nov 2026 16:15:08 +0000
9.30 chart change
View Count: 724
| [2025-08-02 15:56:47] |
| User472677 - Posts: 400 |
At 9.30 chart lises premarket data. Sc feed. Under symbol settings , ? to ????? set to evening session. Chart settings set to enable evening g session but at 9.30 they automatically change to no without me doing anything. I set chart settings again to enable evening session. Nest morning I germt the pre market data and at 9.30 reversion to no takes place again and pre market data disappears. Start a new bar at market open is set to no. And stays at no. I do not want pre market data to disappear. Please help. |
| [2025-08-04 14:42:04] |
Please reply
| [2025-08-04 19:07:09] |
Refer to the following: Chart Session Times: Session Times Automatically Changing Unexpectedly For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-08-06 14:44:56] |
Hi, I was already famiar with the documentation you have indicated. I checked all these things before seeking your help. Could I be missing something or is there something else that is not in the documentation? This is a serious issue for me. Can I send you the logs to look at or you can log on to my system to look at? Please help at your earlies. |
| [2025-08-06 15:34:14] |
Please get us your chartbook so we can take a look. Follow these instructions to get us the chartbook: Support Board Posting Information: Attaching a File (Optional) And please tell us which chart number is showing the issue. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-08-06 19:15:16] |
see attached
| [2025-08-06 20:00:28] |
Which chart is it?
| [2025-08-06 20:59:32] |
Chart 57
| [2025-08-07 14:08:07] |
We are not able to reproduce this with your chart. The times stay correct and the "Use Evening Session" stays on when the time goes from the entered Evening Session to the Main Session. Please get us two images of what you are seeing, one just prior to the change in the chart, and one after the change in the chart. Follow these instructions to get us images: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-08-08 02:48:01] |
Pasting the charts per the instructions is not working. Can I just attach screenshots?
| [2025-08-08 13:47:13] |
Just, a screenshot using whatever method you have available is fine. Just get us before and after images.
| [2025-08-08 18:58:34] |
File attached
| [2025-08-08 19:43:18] |
You have the study named "Load Day Session Only at Open" on chart #104 (as shown in the most recent images you gave us. Refer to the following: Load Day Session Only at Open For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
