Date/Time: Wed, 25 Nov 2026 16:15:06 +0000
Trading Dashboard Tool
View Count: 655
| [2025-08-01 19:04:01] |
| User360283 - Posts: 538 |
Os there a study / tool that would display for example the difference of the HI and LOW from the study "HI/Low for time period extended"? If not it would be a great new tool. Thanks
| [2025-08-01 20:13:18] |
There is not a single study that does this, but it is fairly easy to put together 2 studies that will give you what you want. The first step is to get the difference between the High and the Low from the "High/Low for Time Period" study. To do this, you can use the "Study Subgraphs Subtract/Difference", "Spreadsheet Formula", or "Spreadsheet Study" - depending on what you are comfortable with and what you may already have existing in the chart. But the "Study Subgraphs Subtract/Difference" will be the easiest/fastest option. For the "Study Subgraphs Subtract/Difference", set "Input Study 1" to the High subgraph from the "High/Low for Time Period" study and set "Input Study 2" to be the "Low" subgraph from the "High/Low for Time Period" study. Set other items as desired. Hide this study. Then use the "Text Display for Study" to display the most recent difference value from the "Study Subgraphs Subtract/Difference" study. Refer to the following: Study Subgraphs Subtract/Difference Text Display For Study Chart Studies: Settings and Inputs Tab >> Hide Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-08-01 21:31:12] |
Thanks Maybe you all could make this an option of the study?
