Date/Time: Wed, 25 Nov 2026 16:15:07 +0000
Chart value window display
View Count: 476
| [2025-08-01 15:40:52] |
| User449884 - Posts: 238 |
looking for the option to have the chart value window display immediately when using the tool right now i have to right click and the display value isnt following where im placing the mouse |
| [2025-08-01 17:25:19] |
Refer to the following setting: Chart Drawing Tools: Always On When Chart Values Tool Selected (Tool Settings >> Chart Values >> Chart Values) Note that this applies to the "Compact Tool Values Window". So you need to have the option for "Window >> Show Compact Tool Values Window" enabled. right now i have to right click and the display value isnt following where im placing the mouse
We are not sure what you are doing with regards to the right-click. With regards to the display not following the mouse, this would imply that you are viewing the "Chart Values Window" and not the "Tool Values Window". Refer to the information starting here: Window, CB and CW Menus: Chart Values Window (Window) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
