Date/Time: Wed, 25 Nov 2026 16:24:56 +0000
Moving Control Bar
View Count: 602
[2025-07-31 19:12:01]
SC Support - Posts: 2116
(1) I need to move the control bar on the right side to the bottom.
(2) Then move the line at the bottom that lists my active charts to the Right side where the control bar was.
Can that be accomplished?
It would make my life a lot easier
RS
[2025-07-31 19:17:55]
The Control Bar can be moved per the following:
Control Bar: Moving and Detaching the Control Bar
The MDI Tabs (the ones that list the chart and spreadsheets) can only be set to be at the Top or Bottom. There is no support for them to be on the side. Refer to the following for the Top/Bottom control:
General Settings Window: Show MDI Tabs At (Global Settings >> General Settings >> Windows >> Window Tabs)
The tabs can also not be displayed, which is controlled by the setting just above the one given above.
