Date/Time: Wed, 25 Nov 2026 16:25:02 +0000
Rithmic with Denali
View Count: 868
[2025-07-30 15:43:40]
User141886 - Posts: 3
Hi, I’m wondering if I can use Denali for data feed, but Rithmic for execution? I heard from someone at AMP that Sierra Chart is no longer going to work with Rithmic. If I get the service package 12 and want to execute through Rithmic, will I be able to?
[2025-07-30 15:53:03]
User135243 - Posts: 337
if you prove that you've a live-account, you can subscribe to Deanli realtime data (non-pro fees) and execute with a Rithmic connection
[2025-07-30 16:33:53]
Sierra Chart supports connectivity with Rithmic. So you can use Rithmic for your order routing and use our Denali Exchange Data Feed for your data. To connect to Rithmic (or any data or trading service) you need to be on one of the "Integrated" packages. Refer to the information for the packages at the following link:
Description of Service Packages and Pricing: Packages
To change to a paid package, follow these instructions:
Sierra Chart Purchase and License Information: Instructions
To then connect to Rithmic, follow these instructions:
Rithmic Trading Platform Service: Setup Instructions
And to setup the Denali Exchange Data Feed for the CME Group, follow these instructions:
Note that if you are using Rithmic with a Prop Firm, then that connection is not valid to qualify as a Non-Professional for the CME Group data. Refer to the following:
Denali Exchange Data Feed: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges
If you are using AMP for your broker and you are only trading the CME Group, then we would recommend using our Teton Order Routing service and saving a bit of money and having a much more robust order routing service along with the data from our Denali Exchange Data Feed. Refer to the following:
