Date/Time: Mon, 06 May 2024 01:24:22 +0000
Printing Chart with candles and zones
View Count: 828
[2014-10-07 07:50:31] |
User787778 - Posts: 139 |
When viewing a chart that has a zone in a transparent color, generated from a spreadsheet, one can see both the zone and the candles. But when I print the chart, the zone overwrites the candle and one can't see the candles in the zone. Thanks in advance. |
[2014-10-07 16:03:28] |
Is this a Rectangle tool drawing you are using?
[2014-10-07 17:38:57] |
It is the Trans Fill Rect Top/Bottom from the spreadsheet options
