Date/Time: Wed, 25 Nov 2026 16:25:13 +0000
Using the number bars study I cannot see the numbers inside the bar
View Count: 651
| [2025-07-27 02:06:43] |
| Sylent - Posts: 7 |
I increased the font size but the bars are just too small. I have to zoom in 20x just to see the numbers. I read up on scaling the chart but still couldnt get it to work. I like to zoom in with my mouse wheel and click the price on the right of the chart to scale up and down.
| Attachment Deleted. |
| [2025-07-27 17:53:16] |
| Sierra_Chart Engineering - Posts: 25481 |
You would want to decrease the font size, not increase. Anyway, refer to: Numbers Bars: Scaling a Numbers Bars Chart And: Numbers Bars: Adjusting Volume at Price Multiplier For Larger Increment Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-07-28 02:55:12] |
| User584084 - Posts: 348 |
Go to Chart Settings >> [Chart Data] >> Volume At Price >> Volume at Price Multiplier for Intraday Chart >> Increase from 1 to 4
Date Time Of Last Edit: 2025-07-28 02:55:55
