Date/Time: Sat, 27 Apr 2024 06:29:43 +0000
How to save my Live data feed of GFDL
View Count: 1224
[2014-10-07 03:46:59] |
User38813 - Posts: 20 |
Sir i am using GFDL dta feed . They provide backfill in one min format only and live data feed in tick format. so when ever i relogin my previous days data get converted into one min format so all my data of ask/bid deleted as after refill one min format doesnnot support ask/bid calculated values. so i want to save all my live data so that after backfill all values of ask/bid etc remain saved and didnot get deleted on backfill. So please guide me how to save my live data which i can usesd in future as well.
[2014-10-07 04:17:28] |
so when ever i relogin my previous days data get converted into one min format so all my data of ask/bid deleted as after refill one min format doesnnot support ask/bid calculated values. This is definitely not true so long as you do not re-download the data manually yourself. Sierra Chart will not alter the existing data unless you were to manually re-download the data from a past point in time.Make sure you have a tick by tick data configuration: http://www.sierrachart.com/index.php?page=doc/doc_TickbyTickDataConfiguration.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-10-09 10:46:20] |
Sir as per above link in point number 2 say "Some supported Data and Trading services may not provide historical data in a tick by tick format". I am also mentioning same problem with you.i want to ask how could i save the ask/bid data value provided live by GFDL. As after relogin only threee to four daya data is shown with ask/bid values and all other previous data values got deleted on next trading days. During live trading session all ask/bid data is shown but after three days these get deleted and only latest three days are shown. I want to save all current days data so that all ask/bid values may be saved for ever and i can use it for backtest later. http://www.sierrachart.com/image.php?l=1412851244425.png |
[2014-10-09 20:30:35] |
"Some supported Data and Trading services may not provide historical data in a tick by tick format". I am also mentioning same problem with you.i want to ask how could i save the ask/bid data value provided live by GFDL. We can 100% assure you, this happens automatically and there is nothing to do. Stay connected to the data feed as much as possible so you do not miss any tick by tick data.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-10-09 20:31:05
