Date/Time: Wed, 25 Nov 2026 16:25:08 +0000
Request: Fast access to accounts for order allocation to trade accounts
View Count: 757
[2025-07-24 19:44:14]
Rustam - Posts: 28
Would it be possible to redesign the Trade Activity Log so that you can see the account number, balance etc. and use a clickable box to decide which accounts should be copied? Or an independent window where you have the options? If you have a lot of accounts, it is exhausting and time -consuming to see which accounts you want to trade and then have to select and add them in the menu and first search for other accounts that you don't want to trade and then remove from the list. Just like replicanto. That would be excellent
[2025-07-24 21:39:54]
You can save the accounts that are part of the "Order Allocation To Trade Accounts" with the "Trade Configurations". Therefore, you could have multiple trade configurations for a specific setup, but with different trading accounts setup for each one. Refer to the following:
Order Allocation to Trade Accounts: Order Allocation to Trade Accounts Include in Save Trade Window Configuration
[2025-07-25 12:12:47]
Rustam - Posts: 28
I know that, but it would be nice if you were flexible in the selection of accounts, so that you don't have to save 100 configurations and then have to search and possibly get confused. In the meantime, it is also the case that you lose some accounts and some are added. Then you would have to change all configurations again.
The different configurations do not work if you do not select the correct Leader account. If you have 20 accounts, it can be complicated to remember the leader account for each configuration
[2025-07-28 03:18:55]
User273277 - Posts: 145
This brings up a related issue with order allocation, and resolving it should also bring this issue one step closer to resolution:
If the leader account rejects the trade (price moved on a buy/sell limit/stop, loss limit hit, account locked at broker), all the follower accounts skip the trade also. Follower accounts get out of sync due to this. It would be great if we could trade a sim leader, and have follower accounts be the live accounts.
