Date/Time: Wed, 25 Nov 2026 11:24:17 +0000
PALLADIUM LIVE TRADING ORDERS NOT WORKING
View Count: 517
[2025-07-24 14:27:13]
User624595 - Posts: 267
2025-07-24 10:02:29.844 | Trading message from IB: Order rejected - reason:Invalid Price. Error Code: 201. ServiceOrderID: 14499. InternalOrderID: 26657. *
2025-07-24 10:21:05.792 | Trading message from IB: The price does not conform to the minimum price variation for this contract. Error Code: 110. ServiceOrderID: 14501. InternalOrderID: 26659. *
2025-07-24 10:21:05.792 | New order rejected - The price does not conform to the minimum price variation for this contract. Internal Order ID: 26659. Service Order ID: 14501. Symbol: PA-202509-NYMEX-USD-100. Account: *****
[2025-07-24 14:39:59]
We see that Palladium has a Tick Size from the specifications of 0.5, but in Sierra Chart it is setup as 0.1. We do not know if there was a change at some point. We will have to look into this on our end.
In the meantime, change the entry for "Chart >> Chart Settings >> Symbol >> Tick Size" to be 0.5. Refer to the following:
Chart Settings: Tick Size (Chart >> Chart Settings >> Symbol >> Symbol Settings menu)
If you will be opening new charts for Palladium, then you would also want to change the symbol settings for that tick size for the Palladium symbol. Refer to the following:
Global Symbol Settings: Instructions
[2025-07-27 05:21:03]
Sierra_Chart Engineering - Posts: 25479
Symbol Settings are updated for palladium.
