Date/Time: Wed, 25 Nov 2026 16:25:10 +0000
Difference Indicator Updates
View Count: 558
| [2025-07-23 13:18:23] |
| User57180 - Posts: 14 |
Does SierraChart have any indicators that store bid ask values historically? Secondly, is it possible to get the Difference Bar Indicator to display the difference based on the mid of the bid and ask prices for each instrument and have it update when those values change? Thanks so much.
| [2025-07-23 14:37:21] |
| Sierra_Chart Engineering - Posts: 25481 |
Sierra Chart does store the current Bid and Ask price at every trade in the Intraday data for a symbol. You can see these prices, with this study: Bid & Ask Prices And there are also the Arithmetic studies to accomplish what you want: Using the Basic Arithmetic Studies Also refer to: Data Recording Modes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-07-24 00:39:20] |
I followed the Instructions on Data Recording and appended -BID. My symbol is CLU25-NYMEX-BID. But it does not update when the Bid changes. Should it be? I am set to retain Tick data as per the instructions but not seeing the bid update on the chart.
| [2025-07-24 22:09:34] |
We see absolutely no problems with that symbol: https://www.sierrachart.com/image.php?Image=1753395066824.png It works exactly as it is intended to. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-07-24 22:11:16
| [2025-07-25 15:28:15] |
Can you confirm if it updates the Bid or Ask when the Last changes or when the Bid or Ask changes. I am looking for when the Bid or Ask changes.
| [2025-07-28 13:58:29] |
The chart definitely updates when there is a change with the Bid price. It is not affected by the last trade price or Ask price.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-07-28 14:06:11
