Date/Time: Sun, 28 Apr 2024 20:20:30 +0000
How to copy large amounts of data out of spreadsheets
View Count: 928
[2014-10-06 18:47:06] |
Pawel_Szpak - Posts: 48 |
Hi, I'm trying to copy around 500k lines of data from a spreadsheet study Sierra chart sheet into excel (I prefer to work in excel for analysis). However, using simple select all & copy only results in the first 65,536 lines copying. I'm guessing this might be some kind of clipboard limitation? What would you suggest is the best way to copy large amounts of data out of the sierra chart spreadsheets? I cannot actually open the sierra chart spreadsheet in Excel - it just looks like gibberish - guessing the formats are incompatible? |
[2014-10-06 18:50:23] |
Small follow up. I'm trying to copy it out piecemeal, but actually, selecting any data past row 65,536 in the sierra chart spreadsheet, results in no data copying at all. Attaching log: (Log removed) Date Time Of Last Edit: 2014-10-06 20:13:43
[2014-10-06 20:15:08] |
Are you using the version of Sierra Chart with New Spreadsheets or Old Spreadsheets. We cannot help with a problem like this in the Old Spreadsheets any longer. Anyway, aside from that, the best way to do you want is to select File >> Save As. Set the File Type to Text to save it as a text file and open it in Excel. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-10-06 20:15:29
[2014-10-06 20:18:00] |
I'm not actually sure which version I have. Is there an easy way to check?
[2014-10-06 20:29:56] |
Do you see tabs along the bottom of the Spreadsheet window to switch among the different Sheets? Or do you see a list box at the top left to select a particular Sheet.
[2014-10-06 20:31:04] |
Sheets along the bottom
[2014-10-06 21:00:53] |
This is the Old Spreadsheets. Use the Save As method described previously to save the spreadsheet as a text file. And then open it in excel. This should work fine. If not let us know. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
