Date/Time: Wed, 25 Nov 2026 23:00:07 +0000
How can I password protect Chart books or Charts?
View Count: 709
| [2025-07-22 14:42:25] |
| User566779 - Posts: 31 |
Thanks.
| [2025-07-22 15:48:29] |
You can not. There is a capability to password protect studies that are added to a chart, but there is no provision for password protecting an entire chart and/or chartbook. Refer to the following: Chart Studies: Settings and Inputs Tab >> Protect with Password For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-02-08 05:14:07] |
| User688525 - Posts: 403 |
Hi John, Is it possible to remove a password from a study if forgotten? Thank you |
| [2026-02-09 16:18:03] |
There is not a way around the password if it is forgotten. You would have to redo the study.
| [2026-02-09 18:30:36] |
Hi John, Thanks for confirming. |
