Date/Time: Wed, 25 Nov 2026 16:25:14 +0000
yH, yL, yHrth, yLrth, open, close
View Count: 435
| [2025-07-21 21:51:39] |
| User282547 - Posts: 17 |
a) How can I make the previous day's high and low lines extend all the way to the price scale — that is, stretch to the far right of the chart? Thank you. b) How can I add the RTH session high and low to this previous day's high and low? I'm also sending a screenshot of how I have the session times configured. regards |
| [2025-07-21 21:54:05] |
a) What study are you using to show those lines? b) Since this is a TPO chart, you would need to have a separate chart with just the RTH and use the same study you use in a) to get the high and low. Then you can use the "Study/Price Overlay" to get the lines onto the TPO chart. Refer to the following: Study/Price Overlay Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
