Date/Time: Wed, 25 Nov 2026 16:25:05 +0000
Re: Sierra Chart Password Reset
View Count: 506
[2025-07-21 18:11:15]
Aina Sololala RANDRIANIRINA - Posts: 1
Dear Sierra Chart Development Team,
I hope this message finds you well.
Thank you for your response.
I have definitely planned to use Sierra Chart as my Trading platform.
I would like to request a usability feature that would greatly enhance the
chart navigation experience: the ability to freely drag the chart in both
horizontal and vertical directions using the middle mouse button (or any
assigned mouse button), similar to how it works in platforms like
TradingView.
Currently, Sierra Chart allows horizontal scrolling with left click drag
and vertical adjustment via the Y-axis, but there is no support for a
unified, fluid 2D drag across the chart area. Having this feature would
make multi-timeframe analysis and multi-monitor workflows significantly
smoother, especially for users with complex setups.
Suggested behavior:
- Pressing and holding the middle mouse button (or an assignable key/mouse
button) allows free movement across both axes.
- Optional setting to toggle this behavior on/off in Global or Chart
Settings.
I believe many users who are used to modern interfaces would highly
appreciate this addition.
Thank you for your continued development and excellent support!
[2025-07-21 18:11:50]
The Hand tool allows you to do this.
Note that you have posted from an expired account. For further help, you need to post from an active Sierra Chart account.
