Date/Time: Mon, 29 Apr 2024 22:04:54 +0000
problem
View Count: 1063
[2014-10-06 15:49:03] |
77293A - Posts: 8 |
There is a problem with the story, the price displayed on the inclusion of the sierra
raseel 2000.PNG / V - Attached On 2014-10-06 15:48:37 UTC - Size: 282.75 KB - 350 views |
[2014-10-06 17:14:50] |
We are not understanding what the problem is. Can you briefly describe it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-10-06 17:24:06] |
User11942 - Posts: 298 |
It looks like the same problem I described this am here: TF data problem CQG Missing data for TF from CQG |
[2014-10-07 10:00:29] |
77293A - Posts: 8 |
So this is the problem, it relates TF and Swiss Franc CQG data
[2014-10-07 16:00:02] |
There is a problem where there is missing historical Intraday data for CQG for some symbols, but we cannot solve it at the moment.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-10-07 16:00:36
[2014-10-09 21:21:14] |
77293A - Posts: 8 |
When the problem is corrected ???
[2014-10-09 21:41:41] |
Not sure. Hopefully within a few days. If you try re-downloading the data now, the historical data will be up to date as of this moment. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-10-09 21:41:55
