Date/Time: Wed, 25 Nov 2026 16:25:13 +0000
TASTYTRADE
View Count: 651
| [2025-07-18 19:13:48] |
| russellg - Posts: 14 |
I USE TASTYTRADE. I KNOW I CANT TRADE FUTURES DIRECTLY THRU SIERRA CHART WITH TASTYTRADE. BUT CAN I USE SIERRA CHART REALTIME DATA JUST FOR CHARTING. IF YES, WHAT DO I NEED TO DO FOR THAT?
| [2025-07-21 10:56:28] |
| Sierra_Chart Engineering - Posts: 25481 |
The first thing you need to do is update Sierra Chart to the current version since you are running an older version we can see. Instructions: Software Download: Fast Update And then you will need to use the Denali Exchange Data Feed: Denali Exchange Data Feed However, be aware of the information here: Denali Exchange Data Feed: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-07-21 10:56:45
