Date/Time: Wed, 25 Nov 2026 16:25:08 +0000
Chartbook modification
View Count: 471
| [2025-07-18 18:15:05] |
| User637928 - Posts: 2 |
Hello support I wanted to ask how much is a chartbook modification ? Its basic just adding HH and HL and a area shading. Can you send me a quote? Thanks J |
| [2025-07-20 15:51:48] |
| ForgivingComputers.com - Posts: 1256 |
I can help you. Please send me a copy of the chartbook, and details of what you want. I will then give you a quote. brad@forgivingcomputers.com Date Time Of Last Edit: 2025-07-20 15:52:52
| [2025-07-21 11:01:48] |
| Sierra_Chart Engineering - Posts: 25481 |
You are able to do this yourself. Not totally sure what you are looking for but maybe this study does what you want: Daily OHLC And refer to: Chart Studies: Filling the Area Between Two Study Subgraphs within Same Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-07-21 11:02:12
