Date/Time: Fri, 03 May 2024 04:31:56 +0000
minor annoyance 'files to open on startup'
View Count: 871
[2014-10-06 12:20:44] |
wray - Posts: 12 |
sometime during the course of this last summer my sierra chart program has started to disregard the 'files to open on startup' under global settings, general settings. there are 3 chartbooks (my most commonly used) that open but as i try to modify this list, nothing seems to change. and this is occurring on both my laptop and desktop. now i am manually opening other chartbooks each time i log on to SC and the inconvenience has risen to the point of this support request. perhaps there is a setting i've missed during the course of version updates or something else, i dont know. i am running recent versions on both pc's, but this problem started months back; i cant remember when exactly. thanks in advance |
[2014-10-06 17:56:15] |
We need to understand this better. So if you Add a file to the list, it does not get added? Can you be very precise as to exactly what is not working.
[2014-10-07 14:14:51] |
wray - Posts: 12 |
that is correct. when i add or subtract a file no change occurs when i close then reopen sc. for example at this writing i had 7 different chartbooks set to open. but no change and what opens is 3 previous chartbooks. so i open 'files to open' dbox and remove all chartbooks leaving no files or chartbooks to open at startup. hit apply close sc; reopen sc and the same previously mentioned 3 chartbooks load i chk the 'files to open' and the original 7 chartbooks (ones i just removed) are back as if no change was made. i do have the 'always use data folder' box chkd. |
[2014-10-07 16:07:34] |
This problem has already been solved. Update Sierra Chart with Help >> Download Current Version.
