Date/Time: Wed, 25 Nov 2026 16:38:55 +0000
real time data for future CBOT spread for soybean-CBOT
View Count: 474
| [2025-07-15 19:49:14] |
| User831355 - Posts: 34 |
Hi SC support Unable to open DOM chart for future soybean -CBOT spread between ZSQ2025/ZSX2025. Thks for support. |
| [2025-07-15 19:52:25] |
We are not seeing any issues with accessing this spread and getting the data. What exactly is the issue you are having? Are you able to get the list of spreads? Are you not finding this particular spread? Are you having a problem with the data once you open the spread chart? Something else? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-07-15 20:04:16] |
My issue is that I can not find the whole list of CBOT future soybean spread between different months, therefore unable to open the DOM chart for soybean spread . Thks . |
| [2025-07-15 20:10:33] |
Follow the instructions at the following link: Denali Exchange Data Feed: Denali Exchange Traded Spread Data with Sierra Chart Services For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-07-16 06:54:45] |
Good day Thanks for solving my problem . |
