Date/Time: Wed, 25 Nov 2026 16:39:03 +0000
Cumulative Delta of POC?
View Count: 1322
| [2025-07-15 18:59:23] |
| User993067 - Posts: 200 |
Referencing Numbers Bars SG21..."Cumulative Delta Volume High" Is this the same as renaming the cumulative delta for the POC? ( its referenced right under POC Vol...SG20) If not can this be added to NBCV2? or accessed somehow? |
| [2025-07-15 19:16:03] |
We are not understanding the question. Please give us more information on exactly what you want to know. The descriptions/definitions for the Numbers Bars Calculated Values subgraphs are here: Numbers Bars: Numbers Bars Calculated Values Subgraph Descriptions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-07-16 00:58:11] |
looking to capture the cum BA delta of volume at the POC... using NBCV there is setting for cum BA delta for all volume...SG10 POC Volume at SG20....what is the next calc down at SG21? I would like to capture the BA delta of the POC...not sure what SG21 output is? |
| [2025-07-16 14:51:15] |
SG21 is the "Cumulative Delta Volume High". The subgraph definitions/descriptions are given in the link we gave previously. In that case, it references the "Cumulative Delta Bars - Volume" study, for which the documentation can be found here: Cumulative Delta Bars - Volume The definition of the Cumulative Delta Bars - Volume High is on that page. There is not a way to get the Delta for the POC from the Numbers Bars Calculated Values. You would have to calculate this using the "Spreadsheet Formula". This can be done since the "Alert" syntax allows for a way to access the Bid and Ask volume values at a specific price level. Refer to the following: Study/Chart Alerts And Scanning: Special Functions And the Spreadsheet Formula uses the "Alert Syntax" for entering formulas. Refer to the following: Spreadsheet Formula Therefore, you would enter a formula like the following: =AVAP(ID1.SG42, 0) - BVAP(ID1.SG42, 0) Where ID1 is the ID of the Numbers Bars Calculated Values study and SG42 is the "Point of Control Value" subgraph in the Numbers Bars Calculated Values study. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
