Date/Time: Mon, 29 Apr 2024 00:09:20 +0000
trade activity log
View Count: 1514
[2014-10-06 11:49:20] |
natanibz - Posts: 131 |
Hello, i use CTS, can i see my trades (non-simulated) for example from january 2014 to june? because now i can't. I set the "number of days to save in trade activity log" (general trade settings) but i can't see my trades before july. Thanks |
[2014-10-06 17:49:56] |
Follow the instructions here and make sure you have the correct settings at the top of the Trade Activity Log: https://www.sierrachart.com/index.php?page=doc/doc_TradeActivityLog.php#ViewingHistoricalTA Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-10-07 11:27:01] |
I tried again but i don't have my trades before july. Is it possible that the reason is because the symbols in CTS are changed or maybe because i have downloaded a new SC and so i don't have the old data? |
[2014-10-07 15:56:05] |
This is not due to a symbol change and not due to a new Sierra Chart version. If the settings at the top of the Trade Activity Log are correct, then the data is not there. Maybe the Number of Days to Save in Trade Activity Log setting was not high enough. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-10-08 11:12:04] |
I think that the settings are correct, but i don't see my trades before july. I have attached two images (the account is set to my account number) In the previous post, i meant that if i have canceled my SC and then download a new SC and i did not copy all my old data, maybe now i don't have the old data of my trades. This because if i connect my second SC, that i use with SC historical data feed, with my CTS connection, i don't have any trades. I think because i don't have my data inside in the data folder. Date Time Of Last Edit: 2014-10-08 11:27:14
trade1.PNG / V - Attached On 2014-10-08 11:09:34 UTC - Size: 37.46 KB - 305 views trade2.PNG / V - Attached On 2014-10-08 11:09:45 UTC - Size: 29.67 KB - 316 views |
[2014-10-08 16:42:08] |
If you have installed another copy of Sierra Chart and did not copy the TradeActivityLog.DAT file from your other copy of Sierra Chart, then this definitely is the reason for the problem.
