Date/Time: Wed, 25 Nov 2026 16:39:17 +0000
Screen freezing during market replay and getting verry laggy
View Count: 848
| [2025-07-13 22:10:18] |
| neevaksama - Posts: 78 |
During the market replay, it was very smooth like always. However during the replay itself, I did the following changes: - Gobal Setting > Tool Settings > Applying Tool Configuration to Existing Drawing Updates Text to No - Started drawing more Marker using Marker Tool (10+) - Started drawing more Risk-Reward drawings (5-6) - Started writing more Text(around 5-6 boxes of 3ish lines) - Trade Activity Log increased (definitely not significant, there's 20ish fills) I referenced these changes to High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.33 - Dotted or Dashed Lines >= 2 Pixels in Width and tried relevant fixes for whatever changes I made. But, it is still very very laggy. Was there any changes made or any advice comes to mind in my particular situation? PS: Safe mode did not help |
| [2025-07-14 15:27:40] |
| Sierra_Chart Engineering - Posts: 25481 |
Make sure the Replay Mode is Standard Replay: Replaying Charts: Replay Mode You need to stop the replay for it to go into effect. Also, check how many Chart Drawings there are in Tools >> Manage Chart Drawings Window. Hundreds or thousands of them will have a performance impact. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-07-14 15:28:51
| [2025-07-14 15:41:21] |
Yup, I have been using Standard Replay and I have only about 80-ish drawing. I also realize that text has high impact if I put too many, any reason why? (I only saw High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.33 - Dotted or Dashed Lines >= 2 Pixels in Width and not anything text-based). I will erase all my drawings and update back :) |
| [2025-07-14 15:48:12] |
Yes you can erase all the Chart Drawings and not save the Chartbook, so you can restore them, and see if that solves the problem.
| [2025-07-16 02:41:05] |
| Tony - Posts: 738 |
@neevaksama I used to have a lot of drawings on the chart too, and I tried to replace them with Subgraph by ACSIL coding as much as I can, the performance definitely improved. |
