Date/Time: Fri, 03 May 2024 03:47:49 +0000
historical
View Count: 2074
[2013-03-24 14:35:05] |
user85017 - Posts: 37 |
Hello, I would like to know how can i get 10 years historical data in chart 30mn period, is it possible ? Data provider is transact for future and SC forex dataFXCM for forex I tryed to do it and i have only 2 years in 30mn bar period Thanks Date Time Of Last Edit: 2013-03-24 14:36:11
[2013-03-24 19:16:09] |
10 years is not available but you can get more than 2 years. Please refer to help topic 42.1 here: Http://www.sierrachart.com/index.php?l=doc/helpdetails42.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-03-24 19:39:19] |
Ok thanks i will try
