Date/Time: Wed, 25 Nov 2026 16:25:09 +0000
STOCKS LVL 2
View Count: 2743
| [2025-07-12 02:47:09] |
| Poisson971 - Posts: 1 |
Hello, i'd like to know whats the difference between "nasdaq total view market depth" for 10$ and "us equities consolidated tape" for 17$ ? I'm basically trying to get a DOM with ALL exchanges market depth "nasdaq, nyse, amex..." (not just nasdaq), does "totalview" includes all of these or just nasdaq ? I want to trade small caps stocks. For the consolidated tape, whats the difference from totalview "if" totalview has all the exchanges included ? (i mean, wouldnt it be already present in nasdaq totalview then?) I am considering using sierra chart for stocks trading, i just want a DOM with lvl 2 from ALL exchanges, and a tape with orders from ALL exchanges aswell. Right now i am using DAS trader, which has all datas perfectly, but they dont have any DOM, just the good old "market depth" window, and im used to having a DOM. Regards |
| [2025-07-14 13:45:55] |
Refer to the following: Denali Exchange Data Feed: Nasdaq TotalView Data Feed Notes US Stock/Equities Consolidated Tape Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-07-23 13:31:54] |
| TonyCipriani - Posts: 155 |
Hello, I see that the only way to get market depth data on equities is through the Nasdaq TotalView Data feed which only shows level 2 data for that particular exchange. It would be great if we can have market depth data combined through all exchanges. I checked through other posts and didn't see it mentioned anywhere so just putting it out there. Thank you |
| [2025-07-23 14:27:20] |
| Sierra_Chart Engineering - Posts: 25481 |
Yes we understand. However, there are no plans for this. Market depth data that we have is only from NASDAQ TotalView.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-07-23 14:27:36
