Date/Time: Tue, 17 Nov 2026 18:09:07 +0000
2nd PC in Asia, NQ charts not loading.
View Count: 580
[2025-07-11 14:51:57]
User57752 - Posts: 10
The 1st instance of Sierra is in the US and it is working perfectly.
The 2nd is in Asia so we can trade 24/7 and it is connecting perfectly (Denali-Teton-Broker) but the NQ chart is not loading.
I have checked the obvious, that I have the correct month and year. Only one Sierra is ever connected to Denali-Teton at a time.
The ExampleChartbook is working so I changed a symbol to NQ June 25 by mistake and it loaded. I changed it to Sept.25 and it is Waiting to Download Historical Data, but it doesn’t download.
I can’t figure out what the problem is.
Please check the msg and advise.
[2025-07-11 14:55:52]
2025-07-11 14:41:49.609 | Trade activity files set size: 5
2025-07-11 14:41:49.802 | Reading Internal Order ID file.
2025-07-11 14:41:49.815 | Reading Trade Orders file.
2025-07-11 14:41:49.817 | Reading Trade Positions file.
2025-07-11 14:41:49.819 | Reading Trade Account Data files.
2025-07-11 14:41:49.829 | Software version: 2773 64-bit
2025-07-11 14:41:49.829 | Primary Thread ID: 12324
2025-07-11 14:41:49.829 | Usage end date: 2025-07-31
2025-07-11 14:41:49.829 | Enabled for: Sierra Chart Historical Data Service.
2025-07-11 14:41:49.829 | Enabled for: Denali Real-Time Exchange Data Feed.
2025-07-11 14:41:49.829 | Enabled for: Delayed Denali Exchange Data Feed.
2025-07-11 14:41:49.829 | Enabled for exchange2: CME (Trading Account Required)
2025-07-11 14:41:49.829 | Enabled for exchange2: CBOT (Trading Account Required)
2025-07-11 14:41:49.829 | Enabled for exchange2: COMEX (Trading Account Required)
2025-07-11 14:41:49.829 | Enabled for exchange2: NYMEX (Trading Account Required)
2025-07-11 14:41:49.829 | Allow Support for Sierra Chart Data Feeds is enabled.
2025-07-11 14:41:49.829 | Current selected Data/Trading service: Teton CME Routing
2025-07-11 14:41:49.829 | Custom symbol settings values: enabled
2025-07-11 14:41:49.829 | Chart Update Interval: 400
2025-07-11 14:41:49.829 | Intraday Data Storage Time Unit: 0
2025-07-11 14:41:49.829 | Time Zone: +00:00:00 (UTC+00)
2025-07-11 14:41:49.829 | 2025-07-11 14:41:49 Local computer time in UTC
2025-07-11 14:41:49.829 | 2025-07-11 14:41:49 Local computer time in SC Time Zone
2025-07-11 14:41:49.829 | 2025-07-11 14:41:47 Server time in UTC
2025-07-11 14:41:49.829 | Local computer UTC time and Server UTC time difference: 2 seconds.
2025-07-11 14:41:49.829 | Program path: C:\SierraChart_USA\
2025-07-11 14:41:49.829 | Data Files path: C:\SierraChart_USA\Data\
2025-07-11 14:41:49.829 | OS Version Number: 10.0
2025-07-11 14:41:49.829 | Locale Setting: C
2025-07-11 14:41:49.829 | DLLs: UserContributedStudies_64.dll
2025-07-11 14:41:49.829 | Allowed protected custom studies:
2025-07-11 14:41:49.829 | Crash reporter started: true
2025-07-11 14:41:49.851 | Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures_direct.dtc.trading. Request ID: 1.
2025-07-11 14:41:49.885 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close.
2025-07-11 14:41:50.103 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side.
2025-07-11 14:41:50.103 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed.
2025-07-11 14:41:50.531 | Received 5 login tokens.
2025-07-11 14:41:51.104 | Symbol settings MD5 received. Request ID: 1.
2025-07-11 14:41:51.104 | Symbol settings are up-to-date for sc_futures_direct.dtc.trading.
2025-07-11 14:41:52.354 | Requested user files to download.
2025-07-11 14:41:54.357 |
2025-07-11 14:41:54.359 | Teton CME Routing | Firm: IronBeam
2025-07-11 14:41:54.363 | Teton CME Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11085
2025-07-11 14:41:54.737 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-07-11 14:41:54.737 | DTC Client socket (1) | New receive buffer size: 0
2025-07-11 14:41:54.737 | DTC Client socket (1) | Connecting to IP: 208.185.224.130.
2025-07-11 14:41:54.991 | Teton CME Routing | Network connection to server complete.
2025-07-11 14:41:54.991 | Teton CME Routing | Starting socket receive thread.
2025-07-11 14:41:54.991 | Teton CME Routing | Sending encoding request to server: Binary VLS. Compression: none
2025-07-11 14:41:55.742 | Teton CME Routing | Setting DTC encoding to Binary VLS
2025-07-11 14:41:55.742 | Teton CME Routing | Sending logon request message.
2025-07-11 14:41:56.049 | Teton CME Routing | Received logon response.
2025-07-11 14:41:56.049 | Teton CME Routing | Server Name: SC DTC Server. Build=53505.
2025-07-11 14:41:56.049 | Teton CME Routing | Server protocol version: 8. Client protocol version: 8
2025-07-11 14:41:56.049 | Teton CME Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink3.trading|SymbolSettings=cme_ilink_live.trading.
2025-07-11 14:41:56.049 | Teton CME Routing | Trading is supported.
2025-07-11 14:41:56.049 | Teton CME Routing | Order cancel and replace is supported.
2025-07-11 14:41:56.049 | Teton CME Routing | OCO Orders supported.
2025-07-11 14:41:56.049 | Teton CME Routing | Bracket Orders supported.
2025-07-11 14:41:56.049 | Teton CME Routing | MarketDepthIsSupported: 1
2025-07-11 14:41:56.049 | Teton CME Routing | Connection to server complete.
2025-07-11 14:41:56.049 | No download requests in the queue to start downloads for. | Number times message added: 3
2025-07-11 14:41:56.050 | Teton CME Routing | Performing query for most recent Order Activity Date-Time.
2025-07-11 14:41:56.053 | Teton CME Routing | Requesting historical order activity from server. Start date-time UTC: 00:00:00.000000
2025-07-11 14:41:56.297 | Updated verified funded futures trading account ending date to: 2025-08-10 14:41:56
2025-07-11 14:41:57.605 | Files to Open on Startup | Opening file: ExampleChartbook.cht
2025-07-11 14:41:57.657 | XAUUSD 1 Min #1 | Reloading chart.
2025-07-11 14:41:57.681 | XAUUSD Daily #2 | Reloading chart.
2025-07-11 14:41:57.706 | YMZ24-CBOT 1 Min #3 | Reloading chart.
2025-07-11 14:41:57.726 | TICK-NYSE 1 Min #4 | Reloading chart.
2025-07-11 14:41:57.792 | MESZ24-CME 1 Min #5 | Reloading chart.
2025-07-11 14:41:57.825 | AMZN-NQTV 60 Min #6 | Reloading chart.
2025-07-11 14:41:57.855 | EURUSD Daily #7 | Reloading chart.
2025-07-11 14:41:57.892 | EURUSD 5 Min #8 | Reloading chart.
2025-07-11 14:41:57.913 | MESZ24-CME #9 | Reloading chart.
2025-07-11 14:41:58.124 | MESZ24-CME 1 Min #10 | Reloading chart.
2025-07-11 14:41:58.152 | AAPL 5 Min #11 | Reloading chart.
2025-07-11 14:41:58.176 | BTCUSD_PERP_BINANCE 1 Min #12 | Reloading chart.
2025-07-11 14:41:58.194 | YMZ24-CBOT 10 Min #13 | Reloading chart.
2025-07-11 14:41:58.237 | YMZ24-CBOT 1 Min #3 | Chart data loading complete.
2025-07-11 14:41:58.242 | MESZ24-CME 1 Min #5 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart_USA\Data\MESZ24-CME.scid
2025-07-11 14:41:58.243 | MESZ24-CME 1 Min #5 | Chart data loading complete.
2025-07-11 14:41:58.255 | XAUUSD 1 Min #1 | Chart data loading complete.
2025-07-11 14:41:58.264 | TICK-NYSE 1 Min #4 | Chart data loading complete.
2025-07-11 14:41:58.270 | XAUUSD Daily #2 | Chart data loading complete.
2025-07-11 14:41:58.275 | MESZ24-CME #9 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart_USA\Data\MESZ24-CME.scid
2025-07-11 14:41:58.276 | MESZ24-CME #9 | Chart data loading complete.
2025-07-11 14:41:58.287 | EURUSD Daily #7 | Chart data loading complete.
2025-07-11 14:41:58.294 | EURUSD 5 Min #8 | Chart data loading complete.
2025-07-11 14:41:58.296 | MESZ24-CME 1 Min #10 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart_USA\Data\MESZ24-CME.scid
2025-07-11 14:41:58.298 | MESZ24-CME 1 Min #10 | Chart data loading complete.
2025-07-11 14:41:58.306 | AMZN-NQTV 60 Min #6 | Chart data loading complete.
2025-07-11 14:41:58.315 | BTCUSD_PERP_BINANCE 1 Min #12 | Chart data loading complete.
2025-07-11 14:41:58.318 | Numbers Bars | Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. *
2025-07-11 14:41:58.318 | Numbers Bars | To restore the chart, remove this study. *
2025-07-11 14:41:58.321 | YMZ24-CBOT 10 Min #13 | Chart data loading complete.
2025-07-11 14:41:58.354 | Using Bid/Ask average for last trade price for XAUUSD
2025-07-11 14:41:58.354 | Using symbol data fast lookup vector
2025-07-11 14:41:58.354 | SC Data with Depth | Starting real-time market data updates for: XAUUSD. ID: 1 Service code: fxcm
2025-07-11 14:41:58.361 | SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443
2025-07-11 14:41:58.361 | SC Data with Depth | Requesting security definition data for: XAUUSD. ID: 1
2025-07-11 14:41:58.361 | Starting DelayedDownloadMonitoringTimer
2025-07-11 14:41:58.361 | Starting HDTimeoutTimer
2025-07-11 14:41:58.361 | Added historical Intraday data request for XAUUSD to the queue.
2025-07-11 14:41:58.361 | Intraday data recording state for symbol XAUUSD is set to download 'Pending'.
2025-07-11 14:41:58.364 | Triggering next historical data download in queue.
2025-07-11 14:41:58.369 | Delaying start of download for XAUUSD.
2025-07-11 14:41:58.373 | Teton CME Routing | Starting real-time market data updates for: YMZ24-CBOT. ID: 2
2025-07-11 14:41:58.373 | Teton CME Routing | Subscribing to streaming market data in the service client is not supported. Symbol: YMZ24-CBOT
2025-07-11 14:41:58.373 | Teton CME Routing | Requesting security definition data for: YMZ24-CBOT. ID: 2
2025-07-11 14:41:58.374 | No historical data client is currently set to download historical Intraday data for YMZ24-CBOT.
2025-07-11 14:41:58.374 | Real-time Intraday chart data file updates started for YMZ24-CBOT
2025-07-11 14:41:58.374 | Intraday chart data file opened for YMZ24-CBOT
2025-07-11 14:41:58.377 | SC Data with Depth | Starting real-time market data updates for: TICK-NYSE. ID: 3 Service code: statscalc
2025-07-11 14:41:58.377 | SC Data with Depth | Requesting security definition data for: TICK-NYSE. ID: 3
2025-07-11 14:41:58.377 | Added historical Intraday data request for TICK-NYSE to the queue.
2025-07-11 14:41:58.377 | Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'.
2025-07-11 14:41:58.377 | Triggering next historical data download in queue.
2025-07-11 14:41:58.382 | Teton CME Routing | Starting real-time market data updates for: MESZ24-CME. ID: 4
2025-07-11 14:41:58.382 | Teton CME Routing | Subscribing to streaming market data in the service client is not supported. Symbol: MESZ24-CME
2025-07-11 14:41:58.382 | Teton CME Routing | Requesting security definition data for: MESZ24-CME. ID: 4
2025-07-11 14:41:58.382 | No historical data client is currently set to download historical Intraday data for MESZ24-CME.
2025-07-11 14:41:58.382 | Real-time Intraday chart data file updates started for MESZ24-CME
2025-07-11 14:41:58.382 | Intraday chart data file opened for MESZ24-CME
2025-07-11 14:41:58.383 | Mapping AMZN-NQTV to AMZN-NQTV. Service code: nasdaq_exchange.data
2025-07-11 14:41:58.384 | Delayed Data Feed | Starting real-time market data updates for: AMZN-NQTV (AMZN-NQTV). ID: 5 Service code: nasdaq_exchange.data
2025-07-11 14:41:58.386 | Delayed Data Feed | Connecting to the server ds31.sierracharts.com. Port 10043
2025-07-11 14:41:58.386 | Delayed Data Feed | Requesting security definition data for: AMZN-NQTV (AMZN-NQTV). ID: 5
2025-07-11 14:41:58.386 | Added historical Intraday data request for AMZN-NQTV to the queue.
2025-07-11 14:41:58.386 | Intraday data recording state for symbol AMZN-NQTV is set to download 'Pending'.
2025-07-11 14:41:58.386 | Triggering next historical data download in queue.
2025-07-11 14:41:58.391 | Using Bid/Ask average for last trade price for EURUSD
2025-07-11 14:41:58.391 | SC Data with Depth | Starting real-time market data updates for: EURUSD. ID: 6 Service code: fxcm
2025-07-11 14:41:58.391 | SC Data with Depth | Requesting security definition data for: EURUSD. ID: 6
2025-07-11 14:41:58.396 | Added historical Intraday data request for EURUSD to the queue.
2025-07-11 14:41:58.396 | Intraday data recording state for symbol EURUSD is set to download 'Pending'.
2025-07-11 14:41:58.396 | Triggering next historical data download in queue.
2025-07-11 14:41:58.577 | DTC Client socket (2) | Creating socket.
2025-07-11 14:41:58.577 | DTC Client socket (2) | New receive buffer size: 0
2025-07-11 14:41:58.577 | DTC Client socket (2) | Connecting to IP: 69.39.70.241.
2025-07-11 14:41:58.604 | Mapping AAPL to AAPL. Service code: us_equities_utp_cta_exchange.data
2025-07-11 14:41:58.604 | Delayed Data Feed | Starting real-time market data updates for: AAPL (AAPL). ID: 7 Service code: us_equities_utp_cta_exchange.data
2025-07-11 14:41:58.606 | Delayed Data Feed | Connecting to the server ds33.sierracharts.com. Port 10043
2025-07-11 14:41:58.606 | Delayed Data Feed | Requesting security definition data for: AAPL (AAPL). ID: 7
2025-07-11 14:41:58.606 | Added historical Intraday data request for AAPL to the queue.
2025-07-11 14:41:58.606 | Intraday data recording state for symbol AAPL is set to download 'Pending'.
2025-07-11 14:41:58.606 | Triggering next historical data download in queue.
2025-07-11 14:41:58.609 | Numbers Bars | Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. *
2025-07-11 14:41:58.609 | Numbers Bars | To restore the chart, remove this study. *
2025-07-11 14:41:58.611 | SC Data with Depth | Starting real-time market data updates for: BTCUSD_PERP_BINANCE. ID: 8 Service code: binance_cryptocurrency.exchange.data
2025-07-11 14:41:58.611 | SC Data with Depth | Requesting security definition data for: BTCUSD_PERP_BINANCE. ID: 8
2025-07-11 14:41:58.611 | Added historical Intraday data request for BTCUSD_PERP_BINANCE to the queue.
2025-07-11 14:41:58.611 | Intraday data recording state for symbol BTCUSD_PERP_BINANCE is set to download 'Pending'.
2025-07-11 14:41:58.611 | Triggering next historical data download in queue.
2025-07-11 14:41:58.629 | Teton CME Routing | Security Definition request has been rejected. Reason: Unsupported symbol: YMZ24-CBOT. ID = 2
2025-07-11 14:41:58.637 | Teton CME Routing | Security Definition request has been rejected. Reason: Unsupported symbol: MESZ24-CME. ID = 4
2025-07-11 14:41:58.662 | DTC Client socket (3) | Creating socket.
2025-07-11 14:41:58.662 | DTC Client socket (3) | New receive buffer size: 0
2025-07-11 14:41:58.662 | DTC Client socket (3) | Connecting to IP: 64.152.155.116.
2025-07-11 14:41:58.720 | DTC Client socket (4) | Creating socket.
2025-07-11 14:41:58.720 | DTC Client socket (4) | New receive buffer size: 0
2025-07-11 14:41:58.720 | DTC Client socket (4) | Connecting to IP: 69.39.70.245.
2025-07-11 14:41:58.806 | SC Data with Depth | Network connection to server complete.
2025-07-11 14:41:58.806 | SC Data with Depth | Starting socket receive thread.
2025-07-11 14:41:58.806 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard
2025-07-11 14:41:58.882 | Delayed Data Feed | Network connection to server complete.
2025-07-11 14:41:58.882 | Delayed Data Feed | Starting socket receive thread.
2025-07-11 14:41:58.882 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-07-11 14:41:58.971 | Delayed Data Feed | Network connection to server complete.
2025-07-11 14:41:58.971 | Delayed Data Feed | Starting socket receive thread.
2025-07-11 14:41:58.971 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-07-11 14:41:59.133 | Delayed Data Feed | Setting DTC encoding to Binary VLS
2025-07-11 14:41:59.133 | Delayed Data Feed | Sending logon request message.
2025-07-11 14:41:59.133 | SC Data with Depth | Setting DTC encoding to Binary VLS
2025-07-11 14:41:59.133 | SC Data with Depth | Sending logon request message.
2025-07-11 14:41:59.231 | Delayed Data Feed | Setting DTC encoding to Binary VLS
2025-07-11 14:41:59.231 | Delayed Data Feed | Sending logon request message.
2025-07-11 14:41:59.330 | AAPL[M] 5 Min #11 | Chart data loading complete.
2025-07-11 14:41:59.441 | Delayed Data Feed | Received logon response.
2025-07-11 14:41:59.441 | Delayed Data Feed | Server Name: SC Realtime Server.
2025-07-11 14:41:59.441 | Delayed Data Feed | Server protocol version: 8. Client protocol version: 8
2025-07-11 14:41:59.441 | Delayed Data Feed | Successfully connected.
2025-07-11 14:41:59.441 | Delayed Data Feed | Trading is not supported.
2025-07-11 14:41:59.441 | Delayed Data Feed | MarketDepthIsSupported: 1
2025-07-11 14:41:59.441 | Delayed Data Feed | Restarting real-time data updates for symbol: AMZN-NQTV -> AMZN-NQTV
2025-07-11 14:41:59.472 | SC Data with Depth | Received logon response.
2025-07-11 14:41:59.472 | SC Data with Depth | Server Name: SC Realtime Server.
2025-07-11 14:41:59.472 | SC Data with Depth | Server protocol version: 8. Client protocol version: 8
2025-07-11 14:41:59.472 | SC Data with Depth | Successfully connected.
2025-07-11 14:41:59.472 | SC Data with Depth | Trading is not supported.
2025-07-11 14:41:59.472 | SC Data with Depth | MarketDepthIsSupported: 1
2025-07-11 14:41:59.472 | SC Data with Depth | Restarting real-time data updates for symbol: BTCUSD_PERP_BINANCE
2025-07-11 14:41:59.472 | SC Data with Depth | Restarting real-time data updates for symbol: EURUSD
2025-07-11 14:41:59.472 | SC Data with Depth | Restarting real-time data updates for symbol: TICK-NYSE
2025-07-11 14:41:59.472 | SC Data with Depth | Restarting real-time data updates for symbol: XAUUSD
2025-07-11 14:41:59.574 | Delayed Data Feed | Received logon response.
2025-07-11 14:41:59.574 | Delayed Data Feed | Server Name: SC Realtime Server.
2025-07-11 14:41:59.574 | Delayed Data Feed | Server protocol version: 8. Client protocol version: 8
2025-07-11 14:41:59.574 | Delayed Data Feed | Successfully connected.
2025-07-11 14:41:59.574 | Delayed Data Feed | Trading is not supported.
2025-07-11 14:41:59.574 | Delayed Data Feed | MarketDepthIsSupported: 1
2025-07-11 14:41:59.574 | Delayed Data Feed | Restarting real-time data updates for symbol: AAPL -> AAPL
2025-07-11 14:41:59.754 | Delayed Data Feed | Setting external service identifier for symbol AMZN-NQTV to 488
2025-07-11 14:41:59.754 | Delayed Data Feed | Received security definition for symbol AMZN-NQTV
2025-07-11 14:41:59.785 | SC Data with Depth | Setting external service identifier for symbol BTCUSD_PERP_BINANCE to 16
2025-07-11 14:41:59.785 | SC Data with Depth | Received security definition for symbol BTCUSD_PERP_BINANCE
2025-07-11 14:41:59.785 | SC Data with Depth | Setting external service identifier for symbol EURUSD to 18
2025-07-11 14:41:59.785 | SC Data with Depth | Received security definition for symbol EURUSD
2025-07-11 14:41:59.785 | SC Data with Depth | Setting external service identifier for symbol TICK-NYSE to 1
2025-07-11 14:41:59.785 | SC Data with Depth | Received security definition for symbol TICK-NYSE
2025-07-11 14:41:59.785 | SC Data with Depth | Setting external service identifier for symbol XAUUSD to 62
2025-07-11 14:41:59.785 | SC Data with Depth | Received security definition for symbol XAUUSD
2025-07-11 14:41:59.920 | Delayed Data Feed | Setting external service identifier for symbol AAPL to 17
2025-07-11 14:41:59.920 | Delayed Data Feed | Received security definition for symbol AAPL
2025-07-11 14:42:04.353 | HD Request # 1 | Downloading Intraday chart data for XAUUSD to the file XAUUSD.scid. Service: fxcm
2025-07-11 14:42:04.355 | HD Request # 1 | Download start date-time: 2025-07-11 06:32:20.000000. File last date-time: 2025-07-11 06:32:20.541000
2025-07-11 14:42:04.355 | HD Request # 1 | Using server: ds12.sierracharts.com port 10150
2025-07-11 14:42:04.355 | Socket (5) | Creating socket.
2025-07-11 14:42:04.355 | Socket (5) | New receive buffer size: 0
2025-07-11 14:42:04.355 | Socket (5) | Connecting to IP: 69.39.70.241.
2025-07-11 14:42:04.849 | HD Request # 1 | Setting DTC encoding to Binary VLS
2025-07-11 14:42:04.849 | HD Request # 1 | Sending historical data logon request message.
2025-07-11 14:42:05.122 | HD Request # 1 | Requesting Intraday data. Start date-time: 2025-07-11 06:32:20. Record interval: 0. Symbol: XAUUSD
2025-07-11 14:42:05.367 | HD Request # 1 | Decompressing data.
2025-07-11 14:42:06.370 | HD Request # 1 | Receiving Intraday data for XAUUSD starting at 2025-07-11 06:32:20.000000
2025-07-11 14:42:07.100 | Socket (5) | CloseSocket call.
2025-07-11 14:42:07.100 | Socket (5) | Shutdown started. Waiting for graceful close.
2025-07-11 14:42:07.101 | Historical data download thread signaled to stop.
2025-07-11 14:42:07.101 | HD Request # 1 | Timestamp of first Intraday data file record written: 2025-07-11 06:32:22.000000.
2025-07-11 14:42:07.101 | HD Request # 1 | Received 25407 Intraday data records from 2025-07-11 06:32:20.000000 to 2025-07-11 14:42:04.000000 (8.2 hours. Delay: 3.1 seconds) and wrote 25406 records for XAUUSD
2025-07-11 14:42:07.111 | HD Request # 1 | Add time&sales data | Remembered last file record date-time: 2025-07-11 14:42:04.000000
2025-07-11 14:42:07.111 | Added 36 Time and Sales records to Intraday data file for XAUUSD after download.
2025-07-11 14:42:07.111 | HD Request # 1 | Completion time: 3s.
2025-07-11 14:42:07.111 | HD Request # 1 | Intraday data download complete for XAUUSD. Unique request ID: 1
2025-07-11 14:42:07.111 | Removing historical data download ID 1.
2025-07-11 14:42:07.111 | Real-time Intraday chart data file updates started for XAUUSD
2025-07-11 14:42:07.111 | Intraday chart data file opened for XAUUSD
2025-07-11 14:42:07.111 | HD Request # 1 | Enabling Intraday chart updating for symbol.
2025-07-11 14:42:07.111 | Triggering next historical data download in queue.
2025-07-11 14:42:07.111 | HD Request # 2 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc
2025-07-11 14:42:07.112 | HD Request # 2 | Download start date-time: 2025-07-11 00:00:07.000000. File last date-time: 2025-07-11 00:00:07.000000
2025-07-11 14:42:07.112 | HD Request # 2 | Using server: ds4.sierracharts.com port 10149
2025-07-11 14:42:07.250 | Socket (6) | Creating socket.
2025-07-11 14:42:07.250 | Socket (6) | New receive buffer size: 0
2025-07-11 14:42:07.250 | Socket (6) | Connecting to IP: 64.152.155.113.
2025-07-11 14:42:07.344 | Socket (5) | Socket gracefully closed by remote side.
2025-07-11 14:42:07.344 | Socket (5) | Closed.
2025-07-11 14:42:07.708 | HD Request # 2 | Setting DTC encoding to Binary VLS
2025-07-11 14:42:07.708 | HD Request # 2 | Sending historical data logon request message.
2025-07-11 14:42:07.961 | HD Request # 2 | Requesting Intraday data. Start date-time: 2025-07-11 00:00:07. Record interval: 0. Symbol: TICK-NYSE
2025-07-11 14:42:08.186 | HD Request # 2 | Decompressing data.
2025-07-11 14:42:08.659 | HD Request # 2 | Receiving Intraday data for TICK-NYSE starting at 2025-07-11 00:00:07.000000
2025-07-11 14:42:09.333 | Socket (6) | CloseSocket call.
2025-07-11 14:42:09.333 | Socket (6) | Shutdown started. Waiting for graceful close.
2025-07-11 14:42:09.333 | Historical data download thread signaled to stop.
2025-07-11 14:42:09.334 | HD Request # 2 | Timestamp of first Intraday data file record written: 2025-07-11 08:00:00.000000.
2025-07-11 14:42:09.334 | HD Request # 2 | Received 24130 Intraday data records from 2025-07-11 00:00:07.000000 to 2025-07-11 14:42:08.000000 (14.7 hours. Delay: 1.3 seconds) and wrote 24129 records for TICK-NYSE
2025-07-11 14:42:09.344 | HD Request # 2 | Add time&sales data | Remembered last file record date-time: 2025-07-11 14:42:08.000000
2025-07-11 14:42:09.344 | Added 5 Time and Sales records to Intraday data file for TICK-NYSE after download.
2025-07-11 14:42:09.344 | HD Request # 2 | Completion time: 2s.
2025-07-11 14:42:09.344 | HD Request # 2 | Intraday data download complete for TICK-NYSE. Unique request ID: 2
2025-07-11 14:42:09.344 | Removing historical data download ID 2.
2025-07-11 14:42:09.344 | Real-time Intraday chart data file updates started for TICK-NYSE
2025-07-11 14:42:09.344 | Intraday chart data file opened for TICK-NYSE
2025-07-11 14:42:09.344 | HD Request # 2 | Enabling Intraday chart updating for symbol.
2025-07-11 14:42:09.344 | Triggering next historical data download in queue.
2025-07-11 14:42:09.344 | HD Request # 3 | Downloading Intraday chart data for AMZN-NQTV to the file AMZN-NQTV.scid. Service: nasdaq_exchange.data
2025-07-11 14:42:09.345 | HD Request # 3 | Download start date-time: 2025-07-10 23:59:05.000000. File last date-time: 2025-07-10 23:59:05.482001
2025-07-11 14:42:09.345 | HD Request # 3 | Using server: ds33.sierracharts.com port 10150
2025-07-11 14:42:09.345 | Socket (5) | Creating socket.
2025-07-11 14:42:09.345 | Socket (5) | New receive buffer size: 0
2025-07-11 14:42:09.345 | Socket (5) | Connecting to IP: 69.39.70.245.
2025-07-11 14:42:09.560 | Socket (6) | Socket gracefully closed by remote side.
2025-07-11 14:42:09.560 | Socket (6) | Closed.
2025-07-11 14:42:09.820 | HD Request # 3 | Setting DTC encoding to Binary VLS
2025-07-11 14:42:09.820 | HD Request # 3 | Sending historical data logon request message.
2025-07-11 14:42:09.843 | Opened cached Intraday file: C:\SierraChart_USA\Data\XAUUSD.scid. Thread ID: 11256
2025-07-11 14:42:09.845 | Opened cached Intraday file: C:\SierraChart_USA\Data\TICK-NYSE.scid. Thread ID: 11256
2025-07-11 14:42:10.097 | HD Request # 3 | Requesting Intraday data. Start date-time: 2025-07-10 23:59:05. Record interval: 0. Symbol: AMZN-NQTV
2025-07-11 14:42:10.331 | HD Request # 3 | Decompressing data.
2025-07-11 14:42:10.808 | HD Request # 3 | Receiving Intraday data for AMZN-NQTV starting at 2025-07-10 23:59:05.482000
2025-07-11 14:42:11.296 | HD Request # 3 | Timestamp of first Intraday data file record written: 2025-07-11 08:00:00.347000.
2025-07-11 14:42:11.740 | Socket (5) | CloseSocket call.
2025-07-11 14:42:11.740 | Socket (5) | Shutdown started. Waiting for graceful close.
2025-07-11 14:42:11.741 | Historical data download thread signaled to stop.
2025-07-11 14:42:11.741 | HD Request # 3 | Received 57755 Intraday data records from 2025-07-10 23:59:05.482000 to 2025-07-11 14:27:08.936000 (14.5 hours. Delay: 15.0 minutes) and wrote 57753 records for AMZN-NQTV
2025-07-11 14:42:11.750 | HD Request # 3 | Add time&sales data | Remembered last file record date-time: 2025-07-11 14:27:08.936000
2025-07-11 14:42:11.750 | Added 10 Time and Sales records to Intraday data file for AMZN-NQTV after download.
2025-07-11 14:42:11.751 | HD Request # 3 | Completion time: 2s.
2025-07-11 14:42:11.751 | HD Request # 3 | Intraday data download complete for AMZN-NQTV. Unique request ID: 3
2025-07-11 14:42:11.751 | Removing historical data download ID 3.
2025-07-11 14:42:11.751 | Real-time Intraday chart data file updates started for AMZN-NQTV
2025-07-11 14:42:11.751 | Intraday chart data file opened for AMZN-NQTV
2025-07-11 14:42:11.751 | HD Request # 3 | Enabling Intraday chart updating for symbol.
2025-07-11 14:42:11.751 | Triggering next historical data download in queue.
2025-07-11 14:42:11.751 | HD Request # 4 | Downloading Intraday chart data for EURUSD to the file EURUSD.scid. Service: fxcm
2025-07-11 14:42:11.752 | HD Request # 4 | Download start date-time: 2025-07-11 06:32:20.000000. File last date-time: 2025-07-11 06:32:20.105000
2025-07-11 14:42:11.752 | HD Request # 4 | Using server: ds12.sierracharts.com port 10149
2025-07-11 14:42:11.752 | Socket (6) | Creating socket.
2025-07-11 14:42:11.752 | Socket (6) | New receive buffer size: 0
2025-07-11 14:42:11.752 | Socket (6) | Connecting to IP: 69.39.70.241.
2025-07-11 14:42:11.974 | Socket (5) | Socket gracefully closed by remote side.
2025-07-11 14:42:11.974 | Socket (5) | Closed.
2025-07-11 14:42:12.245 | HD Request # 4 | Setting DTC encoding to Binary VLS
2025-07-11 14:42:12.245 | HD Request # 4 | Sending historical data logon request message.
2025-07-11 14:42:12.519 | HD Request # 4 | Requesting Intraday data. Start date-time: 2025-07-11 06:32:20. Record interval: 0. Symbol: EURUSD
2025-07-11 14:42:12.553 | Opened cached Intraday file: C:\SierraChart_USA\Data\AMZN-NQTV.scid. Thread ID: 8952
2025-07-11 14:42:12.760 | HD Request # 4 | Decompressing data.
2025-07-11 14:42:13.757 | HD Request # 4 | Receiving Intraday data for EURUSD starting at 2025-07-11 06:32:20.000000
2025-07-11 14:42:14.477 | Socket (6) | CloseSocket call.
2025-07-11 14:42:14.477 | Socket (6) | Shutdown started. Waiting for graceful close.
2025-07-11 14:42:14.477 | Historical data download thread signaled to stop.
2025-07-11 14:42:14.478 | HD Request # 4 | Timestamp of first Intraday data file record written: 2025-07-11 06:32:21.000000.
2025-07-11 14:42:14.478 | HD Request # 4 | Received 21483 Intraday data records from 2025-07-11 06:32:20.000000 to 2025-07-11 14:42:13.000000 (8.2 hours. Delay: 1.5 seconds) and wrote 21482 records for EURUSD
2025-07-11 14:42:14.487 | HD Request # 4 | Add time&sales data | Remembered last file record date-time: 2025-07-11 14:42:13.000000
2025-07-11 14:42:14.487 | Added 3 Time and Sales records to Intraday data file for EURUSD after download.
2025-07-11 14:42:14.487 | HD Request # 4 | Completion time: 3s.
2025-07-11 14:42:14.487 | HD Request # 4 | Intraday data download complete for EURUSD. Unique request ID: 4
2025-07-11 14:42:14.487 | Removing historical data download ID 4.
2025-07-11 14:42:14.487 | Real-time Intraday chart data file updates started for EURUSD
2025-07-11 14:42:14.487 | Intraday chart data file opened for EURUSD
2025-07-11 14:42:14.487 | HD Request # 4 | Enabling Intraday chart updating for symbol.
2025-07-11 14:42:14.487 | Triggering next historical data download in queue.
2025-07-11 14:42:14.487 | HD Request # 5 | Downloading Intraday chart data for AAPL to the file AAPL.scid. Service: us_equities_utp_cta_exchange.data
2025-07-11 14:42:14.488 | HD Request # 5 | Download start date-time: 2025-07-10 23:59:58.000000. File last date-time: 2025-07-10 23:59:58.452000
2025-07-11 14:42:14.488 | HD Request # 5 | Using server: ds30.sierracharts.com port 10150
2025-07-11 14:42:14.702 | Socket (5) | Creating socket.
2025-07-11 14:42:14.702 | Socket (5) | New receive buffer size: 0
2025-07-11 14:42:14.702 | Socket (5) | Connecting to IP: 67.214.125.11.
2025-07-11 14:42:14.717 | Socket (6) | Socket gracefully closed by remote side.
2025-07-11 14:42:14.717 | Socket (6) | Closed.
2025-07-11 14:42:14.849 | Opened cached Intraday file: C:\SierraChart_USA\Data\EURUSD.scid. Thread ID: 11256
2025-07-11 14:42:15.211 | HD Request # 5 | Setting DTC encoding to Binary VLS
2025-07-11 14:42:15.211 | HD Request # 5 | Sending historical data logon request message.
2025-07-11 14:42:15.505 | HD Request # 5 | Requesting Intraday data. Start date-time: 2025-07-10 23:59:58. Record interval: 0. Symbol: AAPL
2025-07-11 14:42:15.763 | HD Request # 5 | Decompressing data.
2025-07-11 14:42:16.279 | HD Request # 5 | Receiving Intraday data for AAPL starting at 2025-07-10 23:59:58.452000
2025-07-11 14:42:16.303 | ExtendTheFundedTradingAccountStatusExpirationDate: Sending request.
2025-07-11 14:42:16.799 | HD Request # 5 | Timestamp of first Intraday data file record written: 2025-07-11 08:00:00.078007.
2025-07-11 14:42:17.270 | ExtendTheFundedTradingAccountStatusExpirationDate | Result: {"Result":"The Funded Trading Account Status Expiration Date is more than 25 days into the future. The Date is currently: 2025-08-08"}. Success=true
2025-07-11 14:42:17.669 | Socket (5) | CloseSocket call.
2025-07-11 14:42:17.669 | Socket (5) | Shutdown started. Waiting for graceful close.
2025-07-11 14:42:17.677 | Historical data download thread signaled to stop.
2025-07-11 14:42:17.678 | HD Request # 5 | Received 120825 Intraday data records from 2025-07-10 23:59:58.452000 to 2025-07-11 14:27:15.869000 (14.5 hours. Delay: 15.0 minutes) and wrote 120824 records for AAPL
2025-07-11 14:42:17.687 | HD Request # 5 | Add time&sales data | Remembered last file record date-time: 2025-07-11 14:27:15.869000
2025-07-11 14:42:17.687 | Added 76 Time and Sales records to Intraday data file for AAPL after download.
2025-07-11 14:42:17.687 | HD Request # 5 | Completion time: 3s.
2025-07-11 14:42:17.687 | HD Request # 5 | Intraday data download complete for AAPL. Unique request ID: 5
2025-07-11 14:42:17.687 | Removing historical data download ID 5.
2025-07-11 14:42:17.687 | Real-time Intraday chart data file updates started for AAPL
2025-07-11 14:42:17.687 | Intraday chart data file opened for AAPL
2025-07-11 14:42:17.687 | HD Request # 5 | Enabling Intraday chart updating for symbol.
2025-07-11 14:42:17.687 | Triggering next historical data download in queue.
2025-07-11 14:42:17.687 | HD Request # 6 | Downloading Intraday chart data for BTCUSD_PERP_BINANCE to the file BTCUSD_PERP_BINANCE.scid. Service: binance_cryptocurrency.exchange.data
2025-07-11 14:42:17.688 | HD Request # 6 | Download start date-time: 2025-07-11 06:32:14.000000. File last date-time: 2025-07-11 06:32:14.972000
2025-07-11 14:42:17.688 | HD Request # 6 | Using server: ds4.sierracharts.com port 10149
2025-07-11 14:42:17.688 | Socket (7) | Creating socket.
2025-07-11 14:42:17.689 | Socket (7) | New receive buffer size: 0
2025-07-11 14:42:17.689 | Socket (7) | Connecting to IP: 64.152.155.113.
2025-07-11 14:42:17.889 | Opened cached Intraday file: C:\SierraChart_USA\Data\AAPL.scid. Thread ID: 7072
2025-07-11 14:42:17.920 | Socket (5) | Socket gracefully closed by remote side.
2025-07-11 14:42:17.920 | Socket (5) | Closed.
2025-07-11 14:42:18.136 | HD Request # 6 | Setting DTC encoding to Binary VLS
2025-07-11 14:42:18.136 | HD Request # 6 | Sending historical data logon request message.
2025-07-11 14:42:18.357 | HD Request # 6 | Requesting Intraday data. Start date-time: 2025-07-11 06:32:14. Record interval: 0. Symbol: BTCUSD_PERP_BINANCE
2025-07-11 14:42:18.578 | HD Request # 6 | Decompressing data.
2025-07-11 14:42:19.271 | HD Request # 6 | Receiving Intraday data for BTCUSD_PERP_BINANCE starting at 2025-07-11 06:32:14.000000
2025-07-11 14:42:19.710 | Socket (7) | CloseSocket call.
2025-07-11 14:42:19.710 | Socket (7) | Shutdown started. Waiting for graceful close.
2025-07-11 14:42:19.710 | Historical data download thread signaled to stop.
2025-07-11 14:42:19.711 | HD Request # 6 | Timestamp of first Intraday data file record written: 2025-07-11 06:32:21.000000.
2025-07-11 14:42:19.711 | HD Request # 6 | Received 18725 Intraday data records from 2025-07-11 06:32:14.000000 to 2025-07-11 14:42:16.000000 (8.2 hours. Delay: 3.7 seconds) and wrote 18724 records for BTCUSD_PERP_BINANCE
2025-07-11 14:42:19.720 | HD Request # 6 | Add time&sales data | Remembered last file record date-time: 2025-07-11 14:42:16.000000
2025-07-11 14:42:19.720 | Added 48 Time and Sales records to Intraday data file for BTCUSD_PERP_BINANCE after download.
2025-07-11 14:42:19.720 | HD Request # 6 | Completion time: 2s.
2025-07-11 14:42:19.720 | HD Request # 6 | Intraday data download complete for BTCUSD_PERP_BINANCE. Unique request ID: 6
2025-07-11 14:42:19.720 | Removing historical data download ID 6.
2025-07-11 14:42:19.720 | Real-time Intraday chart data file updates started for BTCUSD_PERP_BINANCE
2025-07-11 14:42:19.720 | Intraday chart data file opened for BTCUSD_PERP_BINANCE
2025-07-11 14:42:19.720 | HD Request # 6 | Enabling Intraday chart updating for symbol.
2025-07-11 14:42:19.720 | No download requests in the queue to start downloads for.
2025-07-11 14:42:19.929 | Socket (7) | Socket gracefully closed by remote side.
2025-07-11 14:42:19.929 | Socket (7) | Closed.
2025-07-11 14:42:24.866 | Opened cached Intraday file: C:\SierraChart_USA\Data\BTCUSD_PERP_BINANCE.scid. Thread ID: 11256
2025-07-11 14:43:51.726 | Numbers Bars | Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. *
2025-07-11 14:43:51.726 | Numbers Bars | To restore the chart, remove this study. *
2025-07-11 14:44:38.434 | Enabling compression for file: C:\SierraChart_USA\Data\MNQM25_FUT_CME.scid
2025-07-11 14:44:38.436 | MNQM25_FUT_CME[M] 5 Min #11 | Reloading chart.
2025-07-11 14:44:38.447 | MNQM25_FUT_CME[M] 5 Min #11 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart_USA\Data\MNQM25_FUT_CME.scid
2025-07-11 14:44:38.448 | MNQM25_FUT_CME[M] 5 Min #11 | Chart data loading complete.
2025-07-11 14:44:38.840 | Mapping MNQM25_FUT_CME to MNQM25. Service code: cme
2025-07-11 14:44:38.840 | Denali Data Feed | Starting real-time market data updates for: MNQM25_FUT_CME (MNQM25). ID: 9 Service code: cme
2025-07-11 14:44:38.842 | Denali Data Feed | Connecting to the server ds27.sierracharts.com. Port 10048
2025-07-11 14:44:38.842 | Denali Data Feed | Requesting security definition data for: MNQM25_FUT_CME (MNQM25). ID: 9
2025-07-11 14:44:38.842 | Added historical Intraday data request for MNQM25_FUT_CME to the queue.
2025-07-11 14:44:38.842 | Intraday data recording state for symbol MNQM25_FUT_CME is set to download 'Pending'.
2025-07-11 14:44:38.842 | Triggering next historical data download in queue.
2025-07-11 14:44:38.843 | Delaying start of download for MNQM25_FUT_CME.
2025-07-11 14:44:38.926 | DTC Client socket (5) | Creating socket.
2025-07-11 14:44:38.926 | DTC Client socket (5) | New receive buffer size: 0
2025-07-11 14:44:38.926 | DTC Client socket (5) | Connecting to IP: 216.200.108.154.
2025-07-11 14:44:39.064 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MNQM25_FUT_CME
2025-07-11 14:44:39.064 | Teton CME Routing | Setting external service identifier for symbol MNQM25_FUT_CME to 283
2025-07-11 14:44:39.064 | Teton CME Routing | Received security definition for symbol MNQM25_FUT_CME
2025-07-11 14:44:39.125 | Denali Data Feed | Network connection to server complete.
2025-07-11 14:44:39.125 | Denali Data Feed | Starting socket receive thread.
2025-07-11 14:44:39.125 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-07-11 14:44:39.329 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-07-11 14:44:39.329 | Denali Data Feed | Sending logon request message.
2025-07-11 14:44:40.078 | Denali Data Feed | Received logon response.
2025-07-11 14:44:40.078 | Denali Data Feed | Server Name: SC Realtime Server.
2025-07-11 14:44:40.078 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-07-11 14:44:40.078 | Denali Data Feed | Successfully connected.
2025-07-11 14:44:40.078 | Denali Data Feed | Trading is not supported.
2025-07-11 14:44:40.078 | Denali Data Feed | MarketDepthIsSupported: 1
2025-07-11 14:44:40.078 | Denali Data Feed | Restarting real-time data updates for symbol: MNQM25_FUT_CME -> MNQM25
2025-07-11 14:44:40.360 | Denali Data Feed | Real-time data for symbol MNQM25_FUT_CME is currently unavailable.
2025-07-11 14:44:40.360 | Denali Data Feed | Received security definition for symbol MNQM25_FUT_CME
2025-07-11 14:44:45.434 | HD Request # 7 | Downloading Intraday chart data for MNQM25_FUT_CME to the file MNQM25_FUT_CME.scid. Service: cme
2025-07-11 14:44:45.436 | HD Request # 7 | Download start date-time: 2024-12-26 23:59:59.000000. File last date-time: 00:00:00.000000
2025-07-11 14:44:45.436 | HD Request # 7 | Using server: ds28.sierracharts.com port 10150
2025-07-11 14:44:45.436 | Socket (6) | Creating socket.
2025-07-11 14:44:45.436 | Socket (6) | New receive buffer size: 0
2025-07-11 14:44:45.436 | Socket (6) | Connecting to IP: 67.214.125.5.
2025-07-11 14:44:45.892 | HD Request # 7 | Setting DTC encoding to Binary VLS
2025-07-11 14:44:45.892 | HD Request # 7 | Sending historical data logon request message.
2025-07-11 14:44:46.161 | HD Request # 7 | Requesting Intraday data. Start date-time: 2024-12-26 23:59:59. Record interval: 0. Symbol: MNQM25
2025-07-11 14:44:46.389 | HD Request # 7 | Decompressing data.
2025-07-11 14:44:46.862 | HD Request # 7 | Receiving Intraday data for MNQM25_FUT_CME starting at 2024-12-27 00:16:00.637000
2025-07-11 14:44:47.330 | HD Request # 7 | Timestamp of first Intraday data file record written: 2024-12-27 00:16:00.637000.
2025-07-11 14:44:50.876 | HD Request # 7 | Error writing historical Intraday data. Error writing record to the file C:\SierraChart_USA\Data\MNQM25_FUT_CME.scid. Error: File error: Windows error code 112: There is not enough space on the disk. * | Number times message added: 33
2025-07-11 14:44:56.723 | MNQU25_FUT_CME[M] 5 Min #11 | Reloading chart.
2025-07-11 14:44:56.740 | MNQU25_FUT_CME[M] 5 Min #11 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart_USA\Data\MNQU25_FUT_CME.scid
2025-07-11 14:44:56.744 | MNQU25_FUT_CME[M] 5 Min #11 | Chart data loading complete.
2025-07-11 14:44:56.754 | HD Request # 7 | Error writing historical Intraday data. Error writing record to the file C:\SierraChart_USA\Data\MNQM25_FUT_CME.scid. Error: File error: Windows error code 112: There is not enough space on the disk. * | Number times message added: 1
2025-07-11 14:44:57.139 | Mapping MNQU25_FUT_CME to MNQU25. Service code: cme
2025-07-11 14:44:57.139 | Denali Data Feed | Starting real-time market data updates for: MNQU25_FUT_CME (MNQU25). ID: 10 Service code: cme
2025-07-11 14:44:57.139 | Denali Data Feed | Requesting security definition data for: MNQU25_FUT_CME (MNQU25). ID: 10
2025-07-11 14:44:57.140 | Added historical Intraday data request for MNQU25_FUT_CME to the queue.
2025-07-11 14:44:57.140 | Intraday data recording state for symbol MNQU25_FUT_CME is set to download 'Pending'.
2025-07-11 14:44:57.140 | Triggering next historical data download in queue.
2025-07-11 14:44:57.186 | HD Request # 7 | Error writing historical Intraday data. Error writing record to the file C:\SierraChart_USA\Data\MNQM25_FUT_CME.scid. Error: File error: Windows error code 112: There is not enough space on the disk. * | Number times message added: 1
2025-07-11 14:44:57.353 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MNQU25_FUT_CME
2025-07-11 14:44:57.353 | Teton CME Routing | Setting external service identifier for symbol MNQU25_FUT_CME to 42003472
2025-07-11 14:44:57.353 | Teton CME Routing | Received security definition for symbol MNQU25_FUT_CME
2025-07-11 14:44:57.426 | HD Request # 7 | Error writing historical Intraday data. Error writing record to the file C:\SierraChart_USA\Data\MNQM25_FUT_CME.scid. Error: File error: Windows error code 112: There is not enough space on the disk. *
2025-07-11 14:44:57.427 | Denali Data Feed | Setting external service identifier for symbol MNQU25_FUT_CME to 42003472
2025-07-11 14:44:57.427 | Denali Data Feed | Received security definition for symbol MNQU25_FUT_CME
2025-07-11 14:44:57.666 | HD Request # 7 | Error writing historical Intraday data. Error writing record to the file C:\SierraChart_USA\Data\MNQM25_FUT_CME.scid. Error: File error: Windows error code 112: There is not enough space on the disk. * | Number times message added: 10
2025-07-11 14:45:35.184 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:45:40.199 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\EURUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:45:40.199 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:45:45.210 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\EURUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:45:45.210 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:45:50.222 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:45:50.222 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\EURUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:45:55.234 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:45:55.234 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:46:00.242 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:46:00.242 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\EURUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:46:00.242 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:46:05.245 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:46:05.245 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\EURUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:46:05.245 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:46:10.256 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:46:10.256 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\EURUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:46:10.256 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:46:15.260 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:46:15.260 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:46:20.262 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:46:20.263 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\EURUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:46:20.263 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:46:25.272 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:46:25.273 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\EURUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:46:25.273 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:46:30.274 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:46:30.274 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\EURUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:46:30.274 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:46:35.275 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:46:35.275 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\EURUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:46:35.275 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:46:40.279 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:46:40.279 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\EURUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:46:40.279 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:46:45.292 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:46:45.293 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:46:45.293 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\EURUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:46:45.293 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:46:50.303 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:46:50.303 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:46:50.303 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AMZN-NQTV.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:46:50.303 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\EURUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:46:50.303 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:46:55.312 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:46:55.312 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:46:55.312 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AMZN-NQTV.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:46:55.312 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\EURUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:46:55.312 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:00.325 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:00.325 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:00.325 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\EURUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:00.325 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:05.331 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:05.331 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:05.331 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\EURUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:05.331 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:10.338 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:10.339 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:10.339 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AMZN-NQTV.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:10.339 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\EURUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:10.339 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:15.339 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:15.339 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:15.339 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AMZN-NQTV.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:15.339 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\EURUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:15.339 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:20.350 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:20.350 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:20.351 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AMZN-NQTV.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:20.351 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\EURUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:20.351 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:25.351 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:25.351 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:25.351 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AMZN-NQTV.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:25.351 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\EURUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:25.351 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:30.360 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:30.360 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:30.361 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AMZN-NQTV.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:30.361 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\EURUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:30.361 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:35.366 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:35.366 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:35.366 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AMZN-NQTV.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:35.366 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\EURUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:35.366 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:40.378 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:40.378 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:40.378 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AMZN-NQTV.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:40.378 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\EURUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:40.379 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:45.391 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:45.391 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:45.391 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AMZN-NQTV.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:45.391 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\EURUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:45.391 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:50.403 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:50.403 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:50.403 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AMZN-NQTV.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:50.403 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\EURUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:50.403 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:55.416 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:55.416 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:55.416 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AMZN-NQTV.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:55.416 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\EURUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:47:55.416 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:48:00.418 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:48:00.418 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:48:00.418 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AMZN-NQTV.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:48:00.418 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\EURUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:48:00.418 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:48:05.421 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:48:05.421 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:48:05.421 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AMZN-NQTV.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:48:05.422 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\EURUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:48:05.422 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:48:10.426 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:48:10.426 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:48:10.427 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AMZN-NQTV.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:48:10.427 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\EURUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:48:10.427 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:48:15.555 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AMZN-NQTV.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:48:15.555 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\EURUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:48:15.555 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:48:20.721 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AMZN-NQTV.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:48:20.721 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\EURUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:48:20.721 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:48:25.730 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AMZN-NQTV.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:48:25.730 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\EURUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:48:25.730 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:48:30.737 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AMZN-NQTV.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:48:30.737 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:48:35.738 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AMZN-NQTV.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:48:35.738 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\EURUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:48:35.738 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:48:40.746 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AMZN-NQTV.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:48:40.747 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\EURUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:48:40.747 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:48:45.750 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AMZN-NQTV.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:48:45.750 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\EURUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:48:45.750 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:48:50.763 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AMZN-NQTV.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:48:50.763 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\EURUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:48:50.763 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:48:55.776 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AMZN-NQTV.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:48:55.776 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\EURUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:48:55.776 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:48:55.776 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\BTCUSD_PERP_BINANCE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:49:00.783 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AMZN-NQTV.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:49:00.783 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\EURUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:49:00.783 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:50:40.898 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:50:50.915 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:50:50.915 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:50:50.916 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:50:55.920 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:50:55.920 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:50:55.920 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:51:00.928 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:51:00.928 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:51:00.929 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:51:05.934 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:51:05.934 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:51:05.935 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:51:10.939 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:51:10.939 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:51:10.939 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:51:15.939 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:51:15.939 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:51:15.940 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:51:20.951 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:51:20.951 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:51:20.951 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:51:25.953 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:51:25.954 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:51:25.954 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:51:30.964 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:51:30.964 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:51:30.964 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:51:33.991 | The message log has been sent to support. *
2025-07-11 14:51:33.991 | HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (7) | Creating socket. Using TLS 1.2.
2025-07-11 14:51:33.991 | HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (7) | New receive buffer size: 0
2025-07-11 14:51:33.991 | HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (7) | Connecting to IP: 64.152.155.19.
2025-07-11 14:51:35.579 | The Message Log was sent. Result: Message Log received. *
2025-07-11 14:51:35.817 | HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (7) | CloseSocket call.
2025-07-11 14:51:35.817 | HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (7) | Shutdown started. Waiting for graceful close.
2025-07-11 14:51:35.964 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:51:35.964 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:51:35.964 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:51:36.039 | HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (7) | Socket gracefully closed by remote side.
2025-07-11 14:51:36.039 | HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (7) | Closed.
2025-07-11 14:51:40.967 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:51:40.967 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:51:40.967 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:51:45.974 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:51:45.974 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:51:45.974 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:51:50.989 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:51:50.989 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:51:50.989 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:51:55.993 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:51:55.993 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:51:55.993 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:52:00.993 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:52:00.993 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:52:00.994 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:52:05.994 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:52:05.994 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:52:05.994 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:52:10.998 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:52:10.998 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:52:10.998 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:52:16.006 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:52:16.006 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:52:16.006 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:52:21.015 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:52:21.015 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:52:21.015 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:52:26.027 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:52:26.027 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:52:26.027 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:52:31.034 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:52:31.034 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:52:31.035 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:52:36.044 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:52:36.044 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:52:36.044 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:52:41.045 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:52:41.045 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:52:41.045 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:52:41.045 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\BTCUSD_PERP_BINANCE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:52:46.056 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:52:46.057 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:52:46.057 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:52:46.057 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\BTCUSD_PERP_BINANCE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:52:51.061 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:52:51.061 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:52:51.061 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:52:56.064 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:52:56.064 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:52:56.064 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:52:56.064 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\BTCUSD_PERP_BINANCE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:53:01.065 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:53:01.065 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:53:01.065 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:53:01.065 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\BTCUSD_PERP_BINANCE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:53:06.081 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:53:06.081 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:53:06.081 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:53:06.081 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\BTCUSD_PERP_BINANCE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:53:11.083 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:53:11.083 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:53:11.083 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:53:11.083 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\BTCUSD_PERP_BINANCE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:53:16.095 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:53:16.095 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:53:16.095 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:53:16.095 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\BTCUSD_PERP_BINANCE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:53:21.105 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:53:21.106 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:53:21.106 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:53:21.106 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\BTCUSD_PERP_BINANCE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:53:26.108 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:53:26.108 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:53:26.108 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:53:26.108 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\BTCUSD_PERP_BINANCE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:53:31.120 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:53:31.120 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:53:31.120 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:53:31.120 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\BTCUSD_PERP_BINANCE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:53:36.125 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:53:36.125 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:53:36.125 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:53:36.125 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\BTCUSD_PERP_BINANCE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:53:41.127 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:53:41.127 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:53:41.127 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:53:41.127 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\BTCUSD_PERP_BINANCE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:53:46.136 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:53:46.136 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:53:46.136 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:53:46.136 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\BTCUSD_PERP_BINANCE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:53:51.139 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:53:51.139 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:53:51.139 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:53:51.139 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\BTCUSD_PERP_BINANCE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:53:56.147 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:53:56.147 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:53:56.147 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:53:56.147 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\BTCUSD_PERP_BINANCE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:00.121 | The message log has been sent to support. *
2025-07-11 14:54:00.121 | HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (7) | Creating socket. Using TLS 1.2.
2025-07-11 14:54:00.122 | HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (7) | New receive buffer size: 0
2025-07-11 14:54:00.122 | HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (7) | Connecting to IP: 64.152.155.19.
2025-07-11 14:54:01.152 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:01.152 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:01.152 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:01.152 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\BTCUSD_PERP_BINANCE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:01.722 | The Message Log was sent. Result: Message Log received. *
2025-07-11 14:54:01.976 | HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (7) | CloseSocket call.
2025-07-11 14:54:01.976 | HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (7) | Shutdown started. Waiting for graceful close.
2025-07-11 14:54:02.201 | HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (7) | Socket gracefully closed by remote side.
2025-07-11 14:54:02.201 | HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (7) | Closed.
2025-07-11 14:54:06.153 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:06.154 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:06.154 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:06.154 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\BTCUSD_PERP_BINANCE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:11.160 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:11.160 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:11.160 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:11.160 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\BTCUSD_PERP_BINANCE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:16.175 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:16.175 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:16.175 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:16.175 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\BTCUSD_PERP_BINANCE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:21.175 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:21.175 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:21.175 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AMZN-NQTV.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:21.175 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:21.175 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\BTCUSD_PERP_BINANCE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:26.175 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:26.176 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:26.176 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:26.176 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\BTCUSD_PERP_BINANCE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:31.188 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:31.188 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:31.188 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AMZN-NQTV.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:31.188 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:31.188 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\BTCUSD_PERP_BINANCE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:36.203 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:36.203 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:36.203 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AMZN-NQTV.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:36.203 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:36.203 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\BTCUSD_PERP_BINANCE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:41.206 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:41.206 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:41.206 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AMZN-NQTV.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:41.206 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:41.206 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\BTCUSD_PERP_BINANCE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:46.213 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:46.213 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:46.213 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AMZN-NQTV.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:46.213 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:46.213 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\BTCUSD_PERP_BINANCE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:51.220 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:51.220 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:51.220 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AMZN-NQTV.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:51.220 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:51.220 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\BTCUSD_PERP_BINANCE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:56.226 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:56.226 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:56.226 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AMZN-NQTV.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:56.226 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:54:56.226 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\BTCUSD_PERP_BINANCE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:55:01.232 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:55:01.232 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:55:01.232 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AMZN-NQTV.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:55:01.232 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\EURUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:55:01.232 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:55:01.232 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\BTCUSD_PERP_BINANCE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:55:06.239 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:55:06.239 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:55:06.239 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AMZN-NQTV.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:55:06.239 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\EURUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:55:06.239 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:55:06.239 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\BTCUSD_PERP_BINANCE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:55:11.241 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:55:11.241 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:55:11.241 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AMZN-NQTV.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:55:11.241 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\EURUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:55:11.241 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:55:11.241 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\BTCUSD_PERP_BINANCE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:55:16.245 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:55:16.245 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:55:16.245 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AMZN-NQTV.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:55:16.245 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\EURUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:55:16.245 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:55:16.245 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\BTCUSD_PERP_BINANCE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:55:21.255 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:55:21.255 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:55:21.255 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AMZN-NQTV.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:55:21.255 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\EURUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:55:21.255 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:55:21.255 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\BTCUSD_PERP_BINANCE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:55:26.256 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:55:26.256 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:55:26.256 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AMZN-NQTV.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:55:26.256 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\EURUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:55:26.256 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\AAPL.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-07-11 14:55:26.256 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart_USA\Data\BTCUSD_PERP_BINANCE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
[2025-07-11 15:24:19]
John - SC Support - Posts: 48555
You have the following:
You are out of drive space. You need to make room on your system.
For help with clearing out Sierra Chart data, refer to the following:
Chart Data and Chart Data Files: Cleaning Up Old and Unused Symbols for Efficiency
