Date/Time: Wed, 25 Nov 2026 16:39:00 +0000
VWAP
View Count: 858
| [2025-07-11 02:14:22] |
| coachted - Posts: 545 |
is there anyway to stop the jump up of the line in VWAP when sessions start. have it start at the session start..this happens on daily weekly monthly etc..i have tried everything the only thing tat wrks is dash but then the line is dashed and not smooth
| [2025-07-11 02:45:09] |
| Tony - Posts: 738 |
what time frame is your chart? I am not quite sure why it's not smooth, a screenshot would be great.
| [2025-07-11 15:01:11] |
If you have the VWAP set to start on the Session start, then there will be a jump in the VWAP at that time, as the VWAP will be exact price at that first bar. Refer to the following: Volume Weighted Average Price (VWAP) with Standard Deviation Lines For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-07-11 15:07:49] |
so for example if i have a full session es chart...18:00 to 17:00 with a weekly vwap on monday the vwap line can jump immensly because it begins a new weekly measurment this jump appears on the screen no matter how i define the draw style....so basically there is nothing that can eliminate that jump correct? please see attached picture
Date Time Of Last Edit: 2025-07-11 15:08:15
| [2025-07-11 15:26:40] |
If the issue you are referring to is the actual line showing during that jump, then you can change the Draw Style to "Dash". But this will make the line itself appear a little differently. Refer to the following: Chart Studies: Dash (ACSIL: DRAWSTYLE_DASH) But if you want the line to display as a line as it is now, then that connection between where the jump occurs is something that will need to stay, as the data is making that jump. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-07-11 16:21:53] |
| blt - Posts: 231 |
... @coachted I use point/6 (you will have nothing between jumps ending points) Try different size and see does it work for you (visually) |
| [2025-07-12 18:56:39] |
is there user access to the code for the Numbers bars study?
| [2025-07-14 14:25:36] |
No. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
