Date/Time: Wed, 25 Nov 2026 16:39:00 +0000
Platform Questions
View Count: 426
[2025-07-09 20:20:46]
User57180 - Posts: 14
Hope you are well. I have a couple questions:
1. Are there settings or a config file that would allow me to shorten
the list of studies in the studies window? I only use about 10 or 15
studies. Would be great to hide others.
2. What would be the easiest way to combine the volume from a strip of
crude contracts?
3. Would it be possible to sum the delta from a strip of crude contracts?
I am on a trial and really enjoying. Thanks,
[2025-07-09 20:20:51]
1. There is no option for this.
2. We need more information on what exactly you are wanting to do.
3. We need more information on what exactly you are wanting to do.
[2025-07-09 20:58:39]
Thanks for your reply on #1.
As for 2 & 3:
Right now I am trading the spread between September and next June Crude oil. There are about 6 or 8 contracts between and I was asking if there was a way to sum the volume of each of them into one indicator so when I look at my crude chart I can see all volume and not just the front month. Thanks
[2025-07-09 21:09:02]
This can be done, but it will require opening a chart for each contract individually, and then getting the volume for each contract and then using the "Study/Price Overlay" to overlay the individual pieces from each chart to a single chart and then adding the pieces together.
If you need help putting this together, let us know, as we are not certain of what volume you are wanting (i.e. for a certain month, or the total contract, or something else), so we do not know the best way to tell you to get this specific piece.
Refer to the following for the "Study/Price Overlay":
Study/Price Overlay Study
There are a few different ways to sum together the pieces, but refer to the Spreadsheet Study and the Spreadsheet Formula for the two easiest ways to do this:
Using the Spreadsheet Study
Spreadsheet Formula
