Date/Time: Tue, 17 Nov 2026 18:09:18 +0000
Denali data fedd free trial
View Count: 2833
| [2025-07-09 18:25:58] |
| User152562 - Posts: 2 |
Hello suppoet team I need denali data feed for checking its data quality before subscribing to it so plz enable its free trial for me so that I can check it properly thanks in advance
| [2025-07-09 19:16:35] |
| John - SC Support - Posts: 48555 |
The Free Trial for the CME Group data is given automatically when you first activate a non-professional exchange for the CME Group with our Denali Exchange Data Feed, assuming you have not received data from us previously. Keep in mind that since the exchanges renew on a calendar month basis, the trial is for the remaining days in the month in which you activate the exchange - for instance if you activate it today (July 9, 2025) you will get the data through the end of July. Everything else applies to getting the trial, therefore you need to be on one of the "Integrated" packages, and you need to have a live, funded, futures trading account. And you need to connect your Sierra Chart software to your live trading account for verification. For information on the packages, refer to the following: Description of Service Packages and Pricing: Packages To change to a paid package, follow these instructions: Sierra Chart Purchase and License Information: Instructions For more information on the requirement for a live, funded, futures trading account for the CME Group Non-Professional designation, refer to the following: Denali Exchange Data Feed: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges To actually setup the exchange, follow the instructions at the following link: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* -- Note that while on a trial you have access to the delayed streaming data for the YM and MES instruments. This data is exactly the same as the real-time data, only it is delayed by 10 minutes and 10 seconds. If you want to view other symbols, but are fine with viewing the delayed data, then you could change from the Trial to one of the "Base" packages. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
