Date/Time: Wed, 25 Nov 2026 16:15:10 +0000
[User Discussion] - Heat map
View Count: 798
| [2025-07-09 14:10:07] |
| cmack1011 - Posts: 201 |
I have been trying to replicate the SC heatmap and large lot tracker studies to resemble the granularity of bookmap while trading small cap stocks. However, it has been difficult. Can you give me any assistance in how to do this? Do I need to add/change my datafeed to gain better stock data or is it not possible to replicate the same degree of detail? Thx CNM |
| [2025-08-12 04:08:58] |
| Sierra_Chart Engineering - Posts: 25481 |
For Market Depth Historical Graph you need to be using NASDAQ TotalView symbols: Denali Exchange Data Feed: Nasdaq TotalView Data Feed Notes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-08-12 04:09:24
