Date/Time: Wed, 25 Nov 2026 16:39:06 +0000
how to delete retracement properties configuration saved TC1, TC2
View Count: 520
| [2025-07-09 13:45:32] |
| Flowdity - Posts: 74 |
I have some properties configuration saved as TC1, TC2 for retracement, I would like to know how to delete them But I couldn't find it in the document, could you please help? |
| [2025-07-09 14:36:33] |
| Sierra_Chart Engineering - Posts: 25481 |
Every Chart Drawing Tool has 24 configurations. They cannot be deleted. They are always in existence but you can change them.: Chart Drawing Tools: Using Multiple Drawing Tool Configurations Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-07-09 14:36:47
