Date/Time: Tue, 24 Nov 2026 18:17:08 +0000
Denali 6M Mexican Peso continuous chart is broken
View Count: 2021
| [2025-08-14 18:50:38] |
| Sierra_Chart Engineering - Posts: 25476 |
ZC settings for Trading Evaluator are the same we use for SC Data. So they do match. If you see any Issue with continuous contract charts for this symbol, let us know and we will see if any modification to those symbol settings are needed. We recommend re-downloading the data if necessary: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data For ZC these are the contract months which are included in a continuous contract chart: HKNZ Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-08-14 19:31:43] |
| juicebro - Posts: 119 |
I'm on the Trading Evaluator - Delayed, to be clear. ZC's default Symbol Settings are HKNUZ contracts. So it does not match HKNZ. But the main issue is there is a gap of data. I've described it before and I thought you reproduced it: I'm on a volume-based back adjusted continuous chart, with Daily candles made with intraday data. The data skips from April 8 2025 to the next bar April 20 2025. https://www.sierrachart.com/image.php?Image=1755199720751.png This is not present on SC Data. On Trading Evaluator - Delayed I've tried with both Symbol Settings HKNZ and HKNUZ, deleting and redownloading data each time but the gap remains. |
| [2025-08-14 20:47:08] |
We adjusted the rollover rules for this ZC symbol. Follow the instructions here to re-download the data for all contract months: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-08-14 22:57:16] |
Thanks. All good now
