Date/Time: Wed, 25 Nov 2026 16:39:19 +0000
Can you copy drawings unidirectionally?
View Count: 587
[2025-07-07 07:46:15]
neevaksama - Posts: 78
As per title, is there way to
1. Copy drawing from Chart #1 to #2
2. Modify #2 without affecting #1
Use case: Multi timeframe analysis but you want to retain the analysis done on a higher timeframe (HTF). In the above example, #1 would be HTF and #2 would be lower timeframe (LTF)
The closet thing I could find was Chart Settings: Allow Modification of Chart Drawings from Other Charts (Chart >> Chart Settings >> Chart Drawing menu) which doesn't fit what I'm looking for
[2025-07-11 18:08:29]
Any advice on this?
[2025-07-11 19:06:40]
Sorry for the delay on this.
There were new options added under the "Edit" menu for "Copy Chart Drawing" and "Paste Chart Drawing". This allows for the copy and paste of drawings between charts, where the drawings are not tied together - i.e. when you paste a drawing it only belongs to that chart.
Refer to the following:
Chart Drawing Tools: Copy and Paste Chart Drawing Operations
[2025-07-13 13:05:36]
Thank you! Although a tad cumbersome, it works exactly as needed fortunately since I don't have alot of drawings on to copy-paste unidirectionally.
