Date/Time: Wed, 25 Nov 2026 20:51:56 +0000
how do I know that I’m now actually looking at live CME data?
View Count: 535
| [2025-07-06 13:29:45] |
| Sivle - Posts: 87 |
I’ve bought Service Package 11 and I’ve activated CME with Market Depth for non-professional trading accounts. My question is: how do I know that I’m now actually looking at live CME data? I’m using a Topstep trading account and connecting via Rithmic Direct – DTC, but I leave the fields for Market Data Username and Market Data Password empty. So how can I be sure that I’m connected to Denali Data Feed and that my CME with Market Depth is running? Maybe a dumb question, but I’m a bit confused. Also – should I check the Message Log? And if so, what exactly should I look for in there? |
| [2025-07-06 14:16:38] |
| Tony - Posts: 738 |
Load study "Clock - RealTime", it display time of last close on a chart, if this time shows behind your system time, then there is delay. |
| [2025-07-07 17:18:27] |
| John - SC Support - Posts: 48658 |
Refer to the information towards the bottom of this section of the documentation where it references an [M] symbol: Denali Exchange Data Feed: Integration with Trading Services You should also read through the rest of that section just for information on how Sierra Chart's data works when you are connected to your trading service. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
