Date/Time: Sat, 04 May 2024 09:24:24 +0000
Ошибка соединения с Rithmic (TopStepTrading)
View Count: 1002
[2014-10-06 01:47:49] |
User17632 - Posts: 10 |
Здравствуйте. Сегодня при запуске платформы не подгрузились данные. торгую через Rithmic (TopStepTrading). После обновления до текущей версии, вообще перестал соединяться с сервером. Откат не помог, больше не могу соединиться. Вот лог на всякий случай. Rithmic Trading | Port for executable: 4605 | 2014-10-06 08:16:08 Listening socket (548), port 4605 | Closed. | 2014-10-06 08:16:08 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-10-06 08:16:08 Rithmic Trading | Connecting to the server 127.0.0.1. Port 4605 | 2014-10-06 08:16:10 Socket (1692) | Error received in OnConnect while connecting. Windows error code 10061: Подключение не установлено, т.к. конечный компьютер отверг запрос на подключение. | 2014-10-06 08:16:11 Socket (1692) | Shutdown and closed. | 2014-10-06 08:16:11 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-06 08:16:11 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-06 08:16:11 Rithmic Trading | Disconnected from the server. | 2014-10-06 08:16:11 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-10-06 08:16:11 File >> Disconnect selected. | 2014-10-06 08:16:11 Rithmic Trading | Disconnected from the server. | 2014-10-06 08:16:11 |
[2014-10-06 02:25:17] |
The Rithmic API software component that Sierra Chart uses requires Windows 7. It does not run on Windows XP. This is the reason for the problem. We see you are running Windows XP. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
