Date/Time: Wed, 25 Nov 2026 07:55:51 +0000
Zoom into everythin
View Count: 724
| [2025-07-03 14:58:44] |
| User360283 - Posts: 538 |
Due to a severe vision impairment I can barely see my charts and stand alone DOM. I can read my emails by using the Enlarge pager to 150% feature. How can I enlarge All y Sierra charts and stand alone DOM by 150%? How ? Thanks |
| [2025-07-03 16:03:45] |
| John - SC Support - Posts: 48648 |
You will need to change the font sizes and possibly some of the sizes/widths for specific graphics items. Refer to the following for how to change fonts: Graphics Settings: Fonts As to the widths/sizes, without specific information on what you want to change, we can not give specific information. As an example though, if you use OHLC Bars, then the following graphics setting (and the 3 items below it) can be changed to affect the widths of the items in the bar: Graphics Settings: Bar High-Low Down Also refer to the items at the following link that can affect how items appear on the screen: Graphics Settings: Graphics Settings - Other Sierra Chart is highly customizable, but you do have the take the time to work through the different items to get everything setup as you want. There is not a single place to have everything changed at once based on a single input. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-09-03 07:36:15] |
| Lowry BigEarth - Posts: 51 |
I haven“t used SC or a while. where is the feature request site is? Couple of years ago I asked mouse roll/ scrollable zoom in-out feature for footprint / cluster charts- like: zoom-to-the-cursor > bar chart to be scrollable/ zoom into footprint/ numbers chart like on ATAS or Quantower. Great feature... is this developed? Thank you.
Date Time Of Last Edit: 2025-09-03 07:37:32
| [2025-09-03 15:33:07] |
We are not certain what exactly you are looking for. There are a few selections for how the scroll wheel on the pointing device functions with respect to the chart. Refer to the following for what is available: General Settings Window: Scroll Wheel (Global Settings >> General Settings >> GUI >> Scroll) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-09-03 15:45:02] |
I read scrolling zooms vertical mainly. How to get the scrolling to zoom vertical and horizontal together?
| [2025-09-03 16:17:47] |
The closest we have is the following: Chart Scale and Scale Adjusting: X & Y Constant Relationship Scaling For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-09-03 16:35:29] |
Thank you, I check it out... Hope it's smth like > https://drive.google.com/file/d/1KL6FVY5QOFMygyFlxuX82-M-Es1uN8BZ/view?usp=drivesdk. Up till numbers bars/ footprint values.
| [2025-09-07 18:37:57] |
| Tony - Posts: 738 |
One of the option is to run Linux system, both Cinnamon and XFCE have zoom features in Accessibility Settings, allows me smoothly zoom in/out with mouse wheel (plus ctrl or alt key), I use this feature every day even without vision issues.
