Date/Time: Sun, 19 May 2024 01:11:41 +0000
Flatten all code in automated trade system
View Count: 928
[2014-10-05 20:21:51] |
User49789 - Posts: 6 |
Hi I'm trying to code the spreadsheet to flatten the entire position after running the length of the 1st standard deviation of a midas vwap. The only way I can get the code to execute every time it tests the DVAL/DVAH is by having the multiple execution option on but when I set the strategy to long exit at the 0.5 standard deviation it only executes 1 sell order. Is there a few to change the quantity of these sell orders or is it possible to completely flatten the position once it breaks this level? Thanks. |
[2014-10-05 23:43:37] |
Sawtooth - Posts: 4000 |
In addition to the formula in L3 to trigger an exit, you'll need a formula in J26 to control the quantity. Or use cell J29. Date Time Of Last Edit: 2014-10-06 01:35:44
[2014-10-09 04:16:05] |
Use the Flatten cell: http://www.sierrachart.com/index.php?page=doc/doc_SystemsAlerts.php#FlattenandCancelWorkingOrders Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
