Date/Time: Wed, 25 Nov 2026 20:52:04 +0000
Volume issue
View Count: 484
| [2025-07-01 07:06:54] |
| User781731 - Posts: 74 |
I have the following settings on my chart: Bar Period Type: Number of Trades Per Bar Bar Period Value: 1 Graph Draw Type: Stair Step on Close Volume Filter Settings: Exclude <= 74, Filter Trade Completely: Yes I have the following studies on my chart: Volume - This study uses Draw Style: Bar to display volume bars Volume - This is a duplicate but Draw Style is set to: Custom Value at Y, to display the volume size above the volume bar Volume At Price Threshold Alert - Bid Volume Threshold: 75, Ask Volume Threshold: 75, Total Volume Threshold: 75. I have set the Draw Style for Bid and Ask to Point, width 8. Draw Style for Total is Ignore As you can see in the screenshot where I have drawn blue circles, there are quite a few instances where the color of the Point does not match the corresponding Volume Bar color. Why is this happening? They obviously should be the same color because the colors are supposed to correspond to whether the trade is on the bid or ask. Should I trust the “Volume” study colors or the “Volume At Price Threshold Alert” study colors as the correct version? Date Time Of Last Edit: 2025-07-01 07:08:41
| [2025-07-01 12:54:50] |
| Sierra_Chart Engineering - Posts: 25483 |
We do not understand this and this is impossible for us to analyze, through screenshots. For an understanding of each study, refer to the documentation for them: Technical Studies Reference Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
