Date/Time: Wed, 25 Nov 2026 20:51:53 +0000
ticker wont load past the 19th
View Count: 466
[2025-06-29 17:17:12]
HeyUgly - Posts: 290
hello screenshot attahced,
this is for MNQu5 - Nasdaq Micro
the NQ mini is fine
i do see the 19th thats noted in the datat limiting will not change. I never changed anything
nor can that number be changed. The mini NQ works just fine but the date is always up to date and not stuck
on the 19th. 2 screenshots to compare them
what is wrong here? I cannot change the date on the micro. the mini works fine
imageCapture.PNG / V - Attached On 2025-06-29 17:16:46 UTC - Size: 44.11 KB - 234 views
imageCapture2.PNG / V - Attached On 2025-06-29 17:16:52 UTC - Size: 44.7 KB - 240 views
[2025-06-30 14:17:25]
John - SC Support - Posts: 48658
The fact that the "Date Range in File To" is not updating means that you are not getting any new data for that symbol.
Please get us your Message Log by following these instructions so we can take a look and see if there is anything specific mentioned as to why:
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
