Date/Time: Wed, 25 Nov 2026 20:51:53 +0000
problem pnl
View Count: 417
| [2025-06-26 19:34:32] |
| User990603 - Posts: 1 |
i have an issue with my pnl the one on sierra doesn t match the one on rithmic. sierra is not showing the correct value
| [2025-06-26 19:59:29] |
| John - SC Support - Posts: 48658 |
Refer to the following to ensure you have the same time frames setup for the Daily P/L in Sierra Chart as what you are expecting in Rithmic: Help With Daily Profit/Loss Value For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-06-27 07:19:35] |
| Tony - Posts: 738 |
@User990603, you might have missed the commissions and fees, I just write my own pnl display with ACSIL, I can do whatever I want, saved so much headache. |
