Date/Time: Wed, 25 Nov 2026 20:51:42 +0000
question re the TPO charts
View Count: 448
| [2025-06-24 18:58:32] |
| User980297 - Posts: 8 |
Can I just ask one more question re the TPO charts - do you know if the TPO charts go back more then 3 months or is that the max historical data we are allowed ? P. |
| [2025-06-24 19:08:50] |
| John - SC Support - Posts: 48658 |
TPO charts do not have any limitation on the amount of time they can display for. This is also true for the data itself, at least as long as you have an active package. Our guess is that you are not using a Continuous Futures Contract in order to get more than 3 months of data for a futures chart. Refer to the following: Continuous Futures Contract Charts Also refer to the following: Loading More Or Less Data into an Intraday Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
