Date/Time: Wed, 25 Nov 2026 20:51:41 +0000
CME Opis data
View Count: 480
| [2025-06-23 22:59:41] |
| LongTermProfit123 - Posts: 9 |
I would like to use the CME Opis data for propane and other petroleum product contracts. How do I access them through SC?
| [2025-06-24 13:59:15] |
| Sierra_Chart Engineering - Posts: 25483 |
Sierra Chart does not support propane. However, you can get NYMEX crude oil options. Refer to: Denali Exchange Data Feed: Denali Futures Options Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-06-24 13:59:31
