Date/Time: Sun, 28 Apr 2024 23:18:32 +0000
Gaps on CL back-adjusted charts
View Count: 855
[2014-10-04 11:11:09] |
User11942 - Posts: 298 |
Fixed by changing number of days for rollover.
Date Time Of Last Edit: 2014-10-04 12:10:16
CLX14 [CB] Daily #9 2014-10-04 06_44_12.671.png / V - Attached On 2014-10-04 11:07:42 UTC - Size: 41.91 KB - 312 views |
[2014-10-04 19:01:04] |
In the case of a commodity like CL, you need to use a volume-based rollover. Not a date-based rollover.
